Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Offroad recovery
    Sep 2006
    Just to make it easy for first-time users... (and correct me if I am wrong) but I believe the eye bolt has a left-hand thread...... So, when you are bogged on a beach somewhere and the tide is coming in fast, you can turn and turn but the thread won't start unless you notice this little "feature"
    cheers
    ..Neil
    Audi Q5 2.0 TDI
    sold and missed: '05 Touareg R5TDI
    SWMBO: '08 Golf Pacific TDI DSG
    Jun 2007
    Sydney, Australia
    I have found the recovery points on the Tiguan.
    This first image show the recovery point on the inside of the front drivers side fog light.
    http://paultan.org/carphotos/display...454&fullsize=1
    The next image shows the recovery point at the rear between the 2 parking sensors also on the drivers side.
    http://paultan.org/carphotos/display...444&fullsize=1
    Point to remember is if you fit the recovery eyelets it may affect your approach/departure angles. Very important for sand dune driving.
    http://paultan.org/carphotos/display...468&fullsize=1
    Last edited by Flipper Dog; 31-01-2010 at 09:29 AM. Reason: Why don't these photos appear?
    Flipper Dog
    Now - T-Roc R, Audi Q5
    Sep 2009
    Harbord, NSW
    One thing to bear in mind when only using one recovery eye to snatch a stuck vehicle is the loading on the chassis.
    If you just need a gentle tug to get the car over a lump it 'should' be fine, but if the car is stuck to its belly pan in gloopy mud the amount of force to get the car unstuck can twist the chassis. That's why most experienced 4WDers will only recover using two hooks and a bridle to spread the chassis loads.
    I'd suggest carrying a shovel to dig out in front of the wheels and a strong flat plate to put the jack on be able to raise up the car and put rocks under the wheels to make the recovery as stress free as possible.
    May 2009
    Western Sydney, NSW
    Blog Entries
    1
    Quote Originally Posted by duncan View Post
    ... but if the car is stuck to its belly pan in gloopy mud the amount of force to get the car unstuck can twist the chassis. That's why most experienced 4WDers will only recover using two hooks and a bridle to spread the chassis loads.
    That's fair enough, but do you have any suggestions on where you would attach the bridle on the Tig?
    I think that's pretty sound advice. Thanks. Of course, it means more things to carry though
    Tiguan TDI, 6spd Tiptronic Auto
    Black, sunroof, comfort pack, off-road tech, tan leather, park assist & roof bars.
    Avg 7.63L/100km over 189,000kms
    Sep 2009
    Harbord, NSW
    Quote Originally Posted by Arctra View Post
    Yep, thats the tricky bit. I not sure you'd be able to do it without removing the front bumper. You'd be better off using the spade and jack to make sure the recovery is as easy as possible prior to doing the snatch.
    The rear is easy as a towbar will act to equalise any forces on the chassis. Just don't use the towball to attach the strap
