Can anyone advise if 112 x 5H will fit a Tiguan?
Other specs 18x8, 57.1 CB, Offset +45
Tyre 235/50
Thanks. I was curious to the H at the end of the stud pattern. Seemed to indicate high offset? So would it be a false +45 or is this irrelevant?
112x5H
112 = 112mm bolt hole diameter
5H = 5 Holes
Pardon my ignorance. and if it's been posted(I did read through as much as I could stand), but will the BMW X5 wheels I had on my T5 Transporter fit on a Tiguan? all four of my wheels are X5 front wheels, so narrower than the rears.
Scirocco and R36/ V6 Passat all have the same PCD and an offset that is suitable for fitment onto a Tiguan (ET40-42). Be aware that wheels for a Golf will fit, however the offset is wrong (ET50-55) and they will sit a long way inside your wheel arches.
There's quite a few Audi wheels that will fit up OK and give a nice OEM+ look.
I have some Audi 5 spoke wheels (fitted by the previous owner) that look quite nice.
They're an option wheel for some of the Audi A4/A5/S5
The ones on my car are 19x9 ET33 which would normally poke a bit, however I have the guard extensions to suit the wheels (or vice versa). The R-line kit would have the same fitment.
Just search for "audi hollow spoke 5" and you'll pull up a number of options for sourcing them. Though they are not a cheap wheel (especially if you buy from Audi).
