Page 52 of 110 FirstFirst ... 242505152535462102 ... LastLast
Results 511 to 520 of 1096
Thread: The Official Mk1 Tiguan Wheel Thread
  1. #511
    Dec 2009
    Canberra
    Can anyone advise if 112 x 5H will fit a Tiguan?
    Other specs 18x8, 57.1 CB, Offset +45
    Tyre 235/50
  2. #512
    Jun 2009
    Quote Originally Posted by 08elf View Post
    Tyre 235/50
    The Tiguan runs a 5x112 bolt pattern as do most of the VW/Audi range other than the big SUV/Amarok ones.
    18x8 ET45 CB57.1 should be fine.
    The tyre size matches the OEM fit.
  3. #513
    Dec 2009
    Canberra
    Thanks. I was curious to the H at the end of the stud pattern. Seemed to indicate high offset? So would it be a false +45 or is this irrelevant?
  4. #514
    112x5H
    112 = 112mm bolt hole diameter
    5H = 5 Holes
    Jan 2015
    Chapman ACT
    Pardon my ignorance. and if it's been posted(I did read through as much as I could stand), but will the BMW X5 wheels I had on my T5 Transporter fit on a Tiguan? all four of my wheels are X5 front wheels, so narrower than the rears.
  6. #516
    Quote Originally Posted by YoYo View Post
    The answer is no not without adapters. The BMW and T5 have a 5x120 stud pattern and Tiguan is 5 x 112.
    Best to get something that already has the correct bolt/stud pattern.
    Jan 2015
    Chapman ACT
    Dang. Thanks.
    What other cars have donor wheels with 112BCD?
  8. #518
    Dang. Thanks.
    Scirocco and R36/ V6 Passat all have the same PCD and an offset that is suitable for fitment onto a Tiguan (ET40-42). Be aware that wheels for a Golf will fit, however the offset is wrong (ET50-55) and they will sit a long way inside your wheel arches.
    There's quite a few Audi wheels that will fit up OK and give a nice OEM+ look.
    I have some Audi 5 spoke wheels (fitted by the previous owner) that look quite nice.
    The Official Mk1 Tiguan Wheel Thread-cp5663876401045477395-jpg
    The Official Mk1 Tiguan Wheel Thread-cp5216767948784843380-jpg
    Jan 2015
    Chapman ACT
    yeah they look good enough for me. Any idea what model they're from?
  10. #520
    They're an option wheel for some of the Audi A4/A5/S5
    The ones on my car are 19x9 ET33 which would normally poke a bit, however I have the guard extensions to suit the wheels (or vice versa). The R-line kit would have the same fitment.
    Just search for "audi hollow spoke 5" and you'll pull up a number of options for sourcing them. Though they are not a cheap wheel (especially if you buy from Audi).
