Should have a full tank of fuel (mine did)
And should be filled with premium unleaded (either 95 or 9.
I believe mine had 95 as i got the tune done and it was a bit gurgly, but fixed itself after i put 98 in.
I only use BP Ultimate.
Not worth the "savings" to put lesser fuel in.
Just wondering if anyone know why the consumption value from the MFD is always lower than the actual consumption by about 0.7-1L/100km? is it to make the car seem more economical?
I do a calculation of the fuel put in (until the first click, which is quite accurate as usually no more fuel will go in after the first click) and the distance covered and over the last 5-7 tanks, it's consistently been over the MFD value. MFD is gives 10.2 when actually it's closer to 11 ish.
I don't trust the MFD remaining range value for this reason.
2008 Passat 3.2 Wagon |
2002 A3 1.8T | APR Stage 1| APR Downpipe | APR dogbone | Diesel Geek Shifter | TT pedals | Forge DV | Saikou Michi OCC | NewSouth Boost Gauge | AVUS Rims | Whiteline Rear Swaybar & ALK | N75J | BMC CDA | APR TIP & TB Hose |
You drive a Tig? I ask as doesn't appear so from your sig?
I have found our Tig to be consistently 0.2 to 0.3 under, so still optimistic, but pretty close. I dont know why they are optimistic, may be to do with the way they calc/average versus real world. I dont remember seeing anything addressing your question but there is lots of stuff in this thread on economy and real versus mfd, so may be worth a trawl thru
Tiguan TSI Catalina blue, Manual
No I don't drive a tig but just thought VW would be using the same method for consumption across the range.
I should measure the amount going in I guess but its hard unless the tank is fully drained (side of the road no fuel).
Guess I can fill it to the "brim" as an indication of full instead of the first click :-P
Posted using Tapatalk
What sort of consumption should i be getting from our 147tsi?
At the moment we are averaging around 500kms to a full tank which seems really bad, car is used majority of the time in stop-start traffic but i still would of thought i'd be getting better figures than that.
MY11 Golf R - Rising Blue - 5DR - DSG - 19" Black OZ Ultralegerra - Leather - Sunroof - MDI - Euro Plates - Milltek Exhaust - Bluefin - SOLD
MY11 Tiguan 147 TSI - DSG - Pepper Grey - Black Leather - RVC - MDI - BT
Depending from the traffic it could be anything between 10L - 12L/100 or even more, so it looks OK to me.
For normal city driving you should around 10L/100km.
