11-12 really isn't that bad in heavy stop/start traffic. Aircon defintely makes a diff, especially where idling a lot in traffic, but generally no where near as much as your driving style etc. You probably already know this, but just in case some thoughts if they help. We are in a country town, so not a lot of lights and more scope to maintain momentum with some anticipation, but I regularly get down into the 8's in short trips into town and back. Have got into the 7's going across town
If you really put the foot down, you will see the current fuel consumption climb up to 50l/100klm! 20-30 is almost par for the course with any kind of acceleration in 2nd. Of course these are for short periods but in stop/start can have a big impact. I get into third and fourth pretty quickly where I dont need to accelerate much (from 30klm/hr or even less in 3rd and from 45-50 in 4th which is quite OK for the car and gearbox as long as you dont ask much from it at low revs). Of course this can be harder in traffic.
stop start driving, especially if using the accelerator and brakes a lot, will kill fuel economy. For fuel economy momentum is your friend and so is full engine braking (ie coasting with your foot off the accelerator). Under those conditions you will notice that the consumption is actually zero, which is not just a trick, it actually is because most modern fuel injected motors cut off the fuel supply altogether in such conditions. And in a high gear you will also coast longer or even accelerate going down a hill while using no fuel at all.
So more you can do to anticipate traffic to reduce avoidable acceleration and braking and maintain your momentum the better.
There are plenty of good sites on economical driving if you are interested, Greenfleet have some good tips or just search on google.
Tiguan TSI Catalina blue, Manual
