OMG .... that spare tyre on the boot outside has got to be the worst thing anybody has ever done to a Tiguan .....
Thats sacrilege ..... looks absolutely dreadful ..... I'd rather walk than be seen in a Tiguan like that ...![]()
According to ELSA the front ends are not interchangeable (if I remember correctly). I'm not sure if this means there is some effect/change to the radiator and other lower front engine bay components in order to lose the chin. I'm sure if you are enterprising enough you'll be able to change it though.
On one of the forums (cant remember if it was Vortex, MyTiguan, or TiguanOwnersClub) I remember seeing that someone retrofitted the offroad button. It was a simple case of wiring in the button to dis/engage offroad, and then enabling the offroad funcationality via VAGCOM. Not sure if it's 100% like the factory fitted option, but it'd be damn close as I understand it a lot of the work is done electronically.
Guys Haldex Performance Part would do part of the job by letting you lock the torque split, but it wouldn't change the accelerator characteristics or hill assist.
Nope. TPMS in the Aus Tig uses the ABS to detect changes in the rotation of the tyres relative to one another... there are no special sesnsors in the wheels. To be honest, the aftermarket in-wheel sensors are a lot more accurate and timely in their warnings and would be a better option. When I get my tyres changed I will be installing an in-wheel wireless TPMS solution.
Go over to MyTiguan and see the solutions there already.
http://mytiguan.com/viewtopic.php?f=...e+spare#p42756
Tiguan TDI, 6spd Tiptronic Auto
Black, sunroof, comfort pack, off-road tech, tan leather, park assist & roof bars.
Avg 7.63L/100km over 189,000kms
[QUOTE]Understood - NOT RETRO fiitable
Would like to find that info - Dealer just say NOT retrofitOn one of the forums (cant remember if it was Vortex, MyTiguan, or TiguanOwnersClub) I remember seeing that someone retrofitted the offroad button. It was a simple case of wiring in the button to dis/engage offroad, and then enabling the offroad funcationality via VAGCOM. Not sure if it's 100% like the factory fitted option, but it'd be damn close as I understand it a lot of the work is done electronically.
YEP understoodGuys Haldex Performance Part would do part of the job by letting you lock the torque split, but it wouldn't change the accelerator characteristics or hill assist.
My understanding is that both the differential speed and pressure monitors were in use in current model. BUT I 've already fitted a Aftermarket TPMS -Am committing the sacriledge/surgery with my Dremel Modifing the "ashtray lid" to integrate it . Anyone know to remove ashtray Storage box would make it easier and would enabe neater wiring to rear of Lighter socketNope. TPMS in the Aus Tig uses the ABS to detect changes in the rotation of the tyres relative to one another... there are no special sesnsors in the wheels. To be honest, the aftermarket in-wheel sensors are a lot more accurate and timely in their warnings and would be a better option. When I get my tyres changed I will be installing an in-wheel wireless TPMS solution.
HOPE TO achieve a neater solution - too low and looks difficult to open hatch - need a swing asideGo over to MyTiguan and see the solutions there already.
Sharkie , only for off road use or when luggage space at a high premium - use a roof box first
Ted Hagstrom
2009 VW Caddy, Whte, TDi, DSG
2009 Tiguan, silverleaf, 103Tdi ,auto, Comfort pack, leather, fogs, Rns510 with RVC
[QUOTE=Tedhaggie;454529]US market legislates true TPMS only, Tiguans there are fitted with the sensors. The rest of us get the software that monitors rotation to determine a flat tyre.My understanding is that both the differential speed and pressure monitors were in use in current model. BUT I 've already fitted a Aftermarket TPMS
I would dearly like to active this tyre monitoring software, I have no need for the off-road part of it.
TDI tiguan in the drive. ParkAssist, comfort, fogs
Service every 15,000, new fault code every 7,500km
2010 Candy White TDI Auto, black leather, bi-Xenons + fogs, DVD plus other gadgets and gizmos to keep the kids quiet!
DON'T DO IT!!!!!!!
PM me with your email address and I will send you extracts from the ELSA discs I have on how to remove the centre consol etc.
Alternatively you could use a 12V fuse tap from the fuse box to get the power you need. See the guide I wrote up on MyTiguan forums:
http://www.mytiguan.com/viewtopic.ph...lit=12v#p47411
So I wonder what else needs to change to fit the off road front end?
I wonder why VWAus didn't bring that end in. Additional ADR testing costs? Or maybe the lower front end can incorporate a bigger radiator for hotter climates? But then why would the South African market get the off road nose?![]()
