Results 21 to 30 of 31
Thread: Off Road Driving (Beach)
  1. #21
    Nov 2009
    Northern NSW
    Quote Originally Posted by jcubed View Post
    Hi Jimbomort,
    Try first with just the spacers, prior to changing the tyres also. And deflate to 12psi.
    Don't worry, the tyres wil stay on as long as you don't do "doughnuts".
    You may just save yourself some money.
    J^3 thanks, we ran them at 18 last time and that worked a treat, so I'd start at least on that. Never even looked close to getting bogged at that, and that was with a lot of underbody drag! Still was after rain, so we'll see. The 12 based on your experience in ZA
    My gut feel last time was that an extra 2 inches would have made for a lot more comfortable level of clearance. but as I wont really be changing the tyres until they are at least close to worn out, may well give it a go first with just the spacers, else a trip out there is probably a year away.
    Tiguan TSI Catalina blue, Manual
  2. #22
    Sep 2009
    QLD
    Hi all (especially jimbomort), here are the new tyres thatwere fitted to the Mrs' Tiggy on the weekend. We were originally going to go with a more aggressive tyre pattern in order to tackle the occasional track, but the Mrs has had a change of mind, and considering its her work car, she wins!!!
    We had the Hancroooooks on from the factory - they must be made of licorice!!! and total rubbish IMO.
    This time we went with a VERY cost effective Maxxis 760 H/T in a size up from the stock size. ie we have fitted 215/70x16.
    This will "fix" the speedo reading, fill out the guards a little, and give a little higher clearance, whilst still being able to venture off the tarmac (a little way). Could have gone to 225/70x16 for a few bucks more - these will easily still fit.
    Here are some quick pics...
    BTW, the tyres were $165 ea fitted and balanced!!!
    2010 Candy White TDI Auto, black leather, bi-Xenons + fogs, DVD plus other gadgets and gizmos to keep the kids quiet!
  3. #23
    Nov 2009
    Northern NSW
    T&M thanks they look great and a good price.
    Let us all know how these tyres are on noise, handling etc as you gain experience with them - ie whether any obivous differences.
    You also might also post what the actual increase in diameter is over the standard tyres?
  4. #24
    Apr 2010
    South Africa
    Tyre profile
    Quote Originally Posted by jimbomort View Post
    You also might post what the actual increase in diameter is over the standard tyres?
    Hi T&M,
    Theoretically, you should get 10.75mm increased clearance. The result of a tyre profile increase is however sometimes surprising.
    On the Hankooks, the Static Loaded Radius, actually went DOWN by 1mm from the 65 to the 70 profile tyre in the SAME series, due to a lower Load Rating, resulting from a softer sidewall.
    Most accurate, is to do a before/after measurement from a sealed surface with the car level, to the inside of the fender edge through the centre of the hub.
  5. #25
    Sep 2009
    QLD
    Hi all,
    Actual diameter increase is in fact, approx 22mm, so height increase is half (jcubed - very good!!) The ride quality and handling response is very good. Noise is almost zero - very quiet.
    So far so good.
  6. #26
    Apr 2010
    South Africa
    Terrain Comparison
    Hi all,
    Related to the beach driving undertaken by some daring Tiguan owners, I thought it might be of interest to some to compare the Stockton beach terrain with what the conditions are like in the Namib desert.
    Hence some video clips from our 2006 expedition with the Forester. You won't see the car itself, as the camera is clamped to the RH side roof rail. Not really demonstrating technique, just showing the scenery, really, from a driver's point-of-view.
    Set the playback resolution to 480p to maximize the video quality. It was originally shot at this resolution, but originates from a point-and-shoot 5Mp Fuji V10, and inevitably has lost some resolution via youtube.
    YouTube - Prado
    YouTube - Chase
    YouTube - Dune Run Edit
  7. #27
    Nov 2009
    Northern NSW
    Quote Originally Posted by T&M View Post
    Hi all,
    So far so good.
    T&M how you going with those tyres, still good after a 3 months experience with them now?
  8. #28
    Jan 2013
    North Avoca
    Just thought I would share my latest beach shot up the mid north coast of NSW
  9. #29
    Mar 2011
    sydney
    Quote Originally Posted by Deavesy View Post
    that beach looks real easy, the sand looks compacted and looks quite solid.
    its the soft stuff you gotta look out for.
    last time i took the tig to stockton there were patches of really soft stuff which i dared not go over, seeing as some of the larger 4 wd's were having some trouble, clearance is the only problem for the tig, if it had that extra 5 cm, i'd be 100% more confident.
  10. #30
    Jan 2013
    North Avoca
    Yeah down by the water was but getting on and off the beach over the dunes wasn't so easy, mate in a hilux got stuck getting off
