As mentioned previously low tyre pressures around 16psi and your selection of highway based tyres is a good setup for the beach. Running less aggressive tyres on the beach is better as the tyre floats over the top instead of digging down for grip. In sand momentum is your friend and don't corner to aggressively as you run 2 risks. You can pop the bead on the tyre and if you go too hard you can do a lap of roof / wheels. As the tyre digs into the sand and trips the car over. I say this as I watched a youngster in a hilux play this game and he discovered that hilux's are indeed breakable.
