Those are the CAN communication wires for Infotainment bus.
It comes with a nice little piggy-back connector there. So what you need to do is depin the same CAN wires from the quadlock connector at the back of the head unit, and then put those into the black connector there where there are empty slots.
Then the bare terminals go back into the same (take note of colours) CAN wires in the quadlock.
Now you have the infotainment CAN bus spliced out to the highline camera control module which can then talk to the head unit.
Red is power. Per OEM wiring that will go into the appropriate fuse location in fuse box C at right side dash panel end.
However you can cut off the terminal and use an add-a-fuse to piggy-back onto a suitable ignition-switched (terminal 15) circuit.
