Results 11 to 20 of 32
Thread: No Acceleration, car in limp mode?
    Oct 2010
    Not the coil pack, it says engine malfunction workshop on display. Don't even have enough power to drive it up car ramps.
    Quote Originally Posted by Suffolk View Post
    SO you have changed the coilpacks?
    Clear the faults and start it up again to see what's still there. Might need the throttle body aligning?
    Did you take out the sprint booster with the ignition on?
    What did the ross tech wiki tell you to look at?
    Oct 2010
    i think it might be throttle body.EPC light is on.Took out the sprint booster with car off and changed the coil pack.Will need to find out have to do a throttle body alignment with ross tech cable.
    MY10 Tiguan 125TSI /APR Stage 2
    Jul 2007
    Brissy
    Unplug the accelerator pedal and clean the contacts and replug, did the trick in my Jetta. Had intermittent combination of EPC & CEL no power on and off.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Oct 2010
    that's the first thing i did with no luck. I just turned the car on and the epic light went off and heaps of oil and smoke came out of the exhaust. Calling tow truck tomorrow morning i think.
    Oct 2010
    Did another scan and now more things came up:
    6 Faults Found:
    000665 - Boost Pressure Regulation
    P0299 - 000 - Control Range Not Reached - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 8
    Reset counter: 255
    Mileage: 70985 km
    Time Indication: 0
    Date: 2015.08.13
    Time: 17:35:06
    Freeze Frame:
    RPM: 4058 /min
    Load: 100.0 %
    Speed: 72.0 km/h
    Temperature: 97.0∞C
    Temperature: 24.0∞C
    Absolute Pres.: 1010.0 mbar
    Voltage: 13.335 V
    000290 - Throttle Position Sensor (G69)
    P0122 - 000 - Signal too Low - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10100000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 72321 km
    Time Indication: 0
    Date: 2015.09.26
    Time: 14:43:47
    Freeze Frame:
    RPM: 762 /min
    Load: 31.0 %
    Speed: 0.0 km/h
    Temperature: 98.0∞C
    Temperature: 68.0∞C
    Absolute Pres.: 1020.0 mbar
    Voltage: 13.208 V
    000546 - Angle Sensor 2 for Throttle (G18
    P0222 - 000 - Signal Too Low - Intermittent - MIL ON
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 72321 km
    Time Indication: 0
    Date: 2015.09.26
    Time: 14:43:47
    Freeze Frame:
    RPM: 762 /min
    Load: 31.0 %
    Speed: 0.0 km/h
    Temperature: 98.0∞C
    Temperature: 68.0∞C
    Voltage: 13.208 V
    005464 - Throttle Actuator (G186)
    P1558 - 000 - Electrical Malfunction - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 72322 km
    Time Indication: 0
    Date: 2015.09.27
    Time: 10:15:29
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 255.0 km/h
    Temperature: 11.0∞C
    Temperature: 16.0∞C
    Voltage: 11.938 V
    008487 - Accelerator Position Sensor 2 (G185)
    P2127 - 000 - Signal too Low - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 2
    Reset counter: 255
    Mileage: 72322 km
    Time Indication: 0
    Date: 2015.09.27
    Time: 10:43:17
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: 48.0∞C
    Temperature: 19.0∞C
    Voltage: 11.938 V
    008482 - Accelerator Position Sensor (G79)
    P2122 - 000 - Signal too Low - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 2
    Reset counter: 255
    Mileage: 72322 km
    Time Indication: 0
    Date: 2015.09.27
    Time: 10:43:17
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: 48.0∞C
    Temperature: 19.0∞C
    Voltage: 11.938 V
    Readiness: 0000 0101
    Oct 2010
    Another update: all faults gone, but heaps of smoke from exhaust, turbo gone.
    What colour is the smoke?
    Oct 2010
    White, shouldn't be blue if turbo?
    If the turbo had done the seals, it would be pumping tons of smoke out. And it would make your eyes water. The smell of burnt synthetic oil is awful. The smoke would hang in the air for ages.
    If it's black, it's over fuelling.
    If it's white doesn't smell bad and dissipates quickly, then it's probably water. Either condensation in the exhaust or blown head gasket.
