You can't keep the highline camera with an RCD330.
Your best bet is to just use a cheap aftermarket camera. It will give a higher quality picture as it isn't being processed to add the guidelines.
You'll need to unplug the highline camera module in the boot on the right hand side and remove it from coding in the gateway installation list.
For steering wheel controls you should have it work out of the box.
