It is likely that it is only running on FWD as the Haldex systems gum up over time. There are filter kits and also the option of replacing the pump. There are a few posts on this in the forum. You can buy the pump from the UK but the filter kits are available locally. There is a very good youtube and pdf on the issue if you search for it.
- You may not post replies
- You may not edit your posts
Forum Rules
