@YellowLemon
Great DIY!
Since I'm going to do the same retrofit, I have some questions:
Do I need to disassemble the door sill to ran the harness along it? Have you taken some photos about the process?
How can I remove the A pillar trim without breaking anything? Photo about this process?
Last one, do you think that with the climatronic I can put the BT module into the dash under the radio, behind the climatronic control? Is there any problem like BT module going to be hot or anything like that?
Regards.
- You may not post replies
- You may not edit your posts
Forum Rules
