Results 11 to 20 of 36
Thread: Mod questions/ideas
    Sep 2014
    Bathurst, NSW
    Would you recommend the diverter? Not sure if its worth the hassle, also did the taillights yesterday and it turned out great, will add pics soon
    Also just got the stub sharam oem aerial fitted, would recommend
    Sent from my SM-G928I using Tapatalk
    An aftermarket recirculating Diverter Valve (DV) typically holds boost better than a stock DV. If you are running standard tune, then it's not really worth it, unless your stock DV is failing and you need to replace it. If you're after some extra sound perhaps consider an aftermarket air filter, a pod with a heat shield / enclosure usually works quite well. There are many manufacturers out there such as CTS, APR Carbonio, Neuspeed, Integarated Engineerinng, VW Racing to name a few....
    Jan 2008
    Sunshine Coast
    The GFB diverter ( a genuine one anyway ) is a very nice bit of kit, but an under the car affair to fit. If you tune it, with any decent tune, it is a must.
    Sep 2014
    Bathurst, NSW
    Quote Originally Posted by Melbourne_Tiggy View Post
    Already got the apr cai and its great for a bit more burble and turbo response might still do it as a "just in case" scemario
    Sep 2014
    Bathurst, NSW
    Quote Originally Posted by Greg Roles View Post
    I've got a mate who is happy to help fit it, between us we should get it done whats yhe wait on shipping
    Sep 2014
    Bathurst, NSW
    Quote Originally Posted by MGV View Post
    Hi Elby. Lowering springs work pretty well on your Tiguan, both for aesthetics & for flatter cornering/acceleration/braking. Effect is even more accentuated with a nice set of 18 or 19 inch rims. Does your 147 have the factory 18" New Yorks?
    Not really a fan of the other 3 mod's you have listed though... Each to his/hers own i suppose! I tried smoking my tails a couple of years ago with film & it looked like i had mauve tail lights so i peeled it off the next morning...
    Does anyone know roughly how much it would cost to get new springs installed?
    Oct 2010
    Average price is between $300-$400 based in Melbourne
    Sep 2014
    Bathurst, NSW
    Ok thanks for the heads up, might shop around, since i'm in ACT but sounds pretty fair
    Sep 2014
    Bathurst, NSW
    Pic of the tail lights
    Attached Thumbnails Attached Thumbnails Mod questions/ideas-20160514_083317-jpg
    Arrawarra
    Nice job, Elby! Any chance of a bit of a close-up/non sideways photo? Might look into that nightshades product, is it removable?
    ps, my springs install was also around 400 a few years ago. Don't forget to factor in an alignment.
