Hi Guys/Girls.
Does anyone know if the MK6 Golf R seats would fit into a 2013 Tiguan ? I may have the opportunity to buy some but I'm unsure if they would fit.
Hi Guys/Girls.
MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
Apart from the physical compatibility there would also be the airbag compatibilty and possible recoding to consider as well
MY 21 T Cross 85TSI Life| Makena Turquoise | Driver Assist Package |
Mods: VCDS tweaks |
Ok, I've found out that they are pretty much plug and play and you can modify the bracket easily so they sit up high.
The downside will be that there is no side guard for the bottom of the seat so you can see the framework underneath and that while the airbag would plug in, it wouldn't be shaped correctly or exit a the right part of the seat to provide adequate side protection. In other words, it's not worth the hassle.
Even if it was perfect insurance would have a field day unless it was a listed modification, and even then they would be rather shaky about modifying anything airbag wise.
Just wondering if anybody has successfully swapped their drivers seat for a sports type seat to give better support; or if there are any mods or other suggestions....thanks.
