Quote Originally Posted by Umai Naa!! View Post
The 'Check deadlock' message is informing you that the vehicle may lock itself once you've removed the keys, and closed the doors.
Ok thanks for that. That makes sense
As for the 'Coming home' function ("Home" refers to where you parked the car, not the car itself. So effectively, Coming home is getting out, Leaving home is getting in.), have you tried leaving the car unlocked for the duration of the 30secs?
Yes, I've left the car unlocked. It's parked inside the garage. So if Leaving Home is getting "into" the car - i.e press the unlock of the remote, the headlights do turn "ON" of an evening for up to 30 secs.
If my memory serves me correct, the lights will go out, as soon as you lock the car. Inversely, they will come on when you unlock it.
Headlights and DRL's turn off the moment I take the key out of the ignition. Yes, the lights come on the moment I unlock.
