What are you looking to fit in? May just be as easy to take the box, stroller, pram, etc to a dealer and see if it works.
I've modified my boot to fit a full size spare otherwise I'd do it
Quick one for anyone who could assist.
If someone could measure their 2012-2014 boot area for me please?
Width across, and depth / and height!
Cheers!
One thing you may want to consider is that the Tiguan has a 60/40 folding rear seat that also slides forward to enable extra space.
The standard configuration in the owners manual doesn't seem that much larger than the golf hatch however if you tilt the seats completely upright and slide them forward you can actually get a lot more storage volume in the boot.
I will try to take some measurements tonight for you.
P.S. i just dropped the inlaws to the airport and managed 5 people in the cabin + 3 suitcases and 3 carry on bags in the boot using only the sliding forward seat fnction.
Just did a quick measure in the dark with a few things in the way, but about 820 deep (rear seat slid back, not forward), 1020 wide & 800ish from the floor to the underside of the hatch opening.
edit: 2010 model, but don't think current model would be any different.
Okay, measurements done.
Boot width is 101cm, height from boot floor to lower roofline is 80cm.
With the rear seats tilted back as per normal and slid as far back as they go you have 80cm of length at floor level and 50cm at top of seat level.
If you tilt the seats forward you gain an extra 10/20cm depending on how much you want to tilt (20cm being vertical).
With the rear seats slid forward as far as they go, you have 100cm of length at the floor level and 85cm at top of seat level.
Again, if you tilt the seats forward you gain an extra 10/20cm.
Finally, if you lay the rear seats down you get a whopping 180cm of length to the back of a comfortable driving position for a 6ft driver.
I should note that the 60/40 rear seat does give you some flexibility for passengers as you can fold the 40 section flat and still have 4 passengers but get access to storage in the seating cabin area.
2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
Here's mine loaded up for a camping trip with the rears folded flat:
I can get a full size ladies bike in the back, as well as a single mattress (almost - can't close the tailgate)
TDI tiguan in the drive. ParkAssist, comfort, fogs
Service every 15,000, new fault code every 7,500km
Maybe we shouldn't ask what you were up to on that particular day!![]()
