Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: lower control arms
  1. #21
    Erskineville, NSW
    Quote Originally Posted by istudio View Post
    Sorry for digging an old post. I went to my dealership today and they are asking for $750 for replacing front bushes on both LCAs. Is that a fair go or nah?
    Did they provide an itemised quote? It sounds high. I would suggest you seek other quotes from either an independant VW Specialist (a few out your way) or a suspension specialist.
    I'm surprised the front bushes have died & not the rears as well.
  2. #22
    Mar 2012
    Pennant Hills, NSW
    nope they didnt. just a comment on the invoice and some very brief verbal description by a lady at the receiption. thats why i thought its a bit fishy
    Attached Thumbnails Attached Thumbnails lower control arms-tig-jpg
  3. #23
    Erskineville, NSW
    So do they mean the front bushes on the front lower control arm or do they mean the bushes (all of them) on the front lower control arm.
    Either way, you can buy a pair of alloy arms with bushes for $590 and it takes about 2 hours (RH side is easy, LH side the DSG gets in the way).
    If it's just the rear bush (that's what usually cracks), you can buy a pair of Febi bushes for $60 and labour will be about 2.5hrs or replacement steel arms for $150 each plus 2 hrs labour.
    I'm pretty sure you'd get out of this for <$500
  4. #24
    Jun 2017
    Sydney NSW
    My Tig is a 2012 and I replaced both front LCA bushes with Lemfoerder aftermarket units bought from Pelican Parts in the US. USD59 for the pair (that's including the alloy mount, not the type that has to be pressed in) - also bought two rear Bilstein shocks and two front sway bar link rods. All those parts cost me USD250 + shipping which was $80 but got here in four days. Saved a lot as the place I have been loyal to quoted A$550 to replace the rear shocks and $240 per side for the aft LCA bushes so the total for just that would have been $1030. I bought all new mounting bolts for the LCA bush mounts which was another AU$40 - its recommended as they are the single use type bolt.
    The aft LCA bushes took me about an hour 15 min for the first and a bit over an hour the other side. I also bought a set of sub-frame alignment studs to relocate the alloy bush holder in its original place but got a wheel alignment done afterward anyway.
    I would have liked to have done the forward bushes as well but they are pressed into the control arm itself so the option is replacing the whole suspension arm or buying bushes and removing the arms from the car and taking them to a workshop to press them out and new ones back in. It's a lot more work too because the front bush / arm mounting bolt can't clear the transmission without dropping the sub-frame - I didn't think that would be an easy thing with just hand tools and floor jack and car stands.
    Rear shocks were a breeze - about an hour each.
  5. #25
    Mar 2012
    Pennant Hills, NSW
    Thanks brad, I will have a look underneath my tig. I would suspect the front bushes on the front LCA.
  6. #26
    Mar 2012
    Pennant Hills, NSW
    Quote Originally Posted by pistoncranky View Post
    Very informative. Cheers mate. Let me have a look and see what gone wrong.
