Results 1 to 10 of 15
Thread: Losing radiator coolant
    Jun 2011
    Hey,
    I have done 45,000km on my 2009 tiguan and just did a service a few days ago. The mechanic told me that there was only around 30% coolant left! He was kind of suprised so wondering if you guys have any experience or knowledge on this?
    What can cause big losses in coolant?
    Adelaide hills, SA
    He most likely meant that the concentration of the coolant was 30%. The minimum VW recommended is 40%. Did you top up the coolant or did your mechanic topped up using water only?
    I would recommend that you get the water pump checked and cooling system pressure tested. Coolant leaking from the water pump would leave the trail of pink/red residue on the engine, visible from under the neath. If you don't find the leak, than drain 1.5L from the cooling system and replace it with 1.5L VAG coolant (available from your dealer).
    Jun 2011
    I haven't touched the coolant since I've bought it but I've had it serviced at VW all the time. I will check it after the weather calms down a bit. Thanks.
    Btw if anybody here drives a auto TSI, have any of you noticed that the car holds the gear longer than usual after some enthusiastic driving in normal mode? (not sport) For me it's always stuck in 4th for a long time and doesn't want to go to 5th. Goes back to normal after changing to up with +/-.
    Dec 2008
    Sydney/Canberra
    Tiguans have always been a bit up-and-down with their coolant.
    The level usually drops a few times below minimum in the early stages of life, as they burp out the air bubbles. The topping up with water does dilute the mixture a little, though.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Adelaide hills, SA
    That's truth, I topped up 250ml in ours after 1st week of driving. It's been good since.
    May 2011
    Carina Heights, Queensland
    Thanks Transporter, that is what mine has done in the first 1000K, now I'm not so concerned.
    One question - I took the car for a check on the coolant level - the mechanic filled the tank to about 60mm over the MAX level line - when the car was hot. The manual says in BOLD print "Do not fill over the top line" - could this create a problem ? or is it just "burping out the bubbles" as Umai Naa says ??
    Adelaide hills, SA
    I would remove the excess of the coolant (only do it when engine is cold).
    Arrawarra
    My coolant reservoir seems to like it sitting on the 'minimum' mark...
    Have topped it up a tad, twice in 22000, only with <250ml or so, but it seems to fall back to the low mark, then stay there. Anyone else notice this?
    Adelaide hills, SA
    Quote Originally Posted by MGV View Post
    Is that with the engine at the operating temperature?
    Dec 2008
    Sydney/Canberra
    Quote Originally Posted by jctee View Post
    Perhaps the technician is pre-empting that the coolant level may drop a little again, thus saving you the inconvenience of returning to the dealership for a top-up.
    '01 Beetle 2.0
