After a month of testing I feel that these pads have broken in. I'm quite happy with the combination and I feel that there is more modulation before ABS. Initial bit is good and a bit more finess is required for normal braking. I haven't had any noise and there is far less brake dust sticking to wheels. If I remember, I will update with how long they last.
Fitment was straight forward apart from the M14 XZN bit required for the rear callipers. It should also be noted that the calliper bolts on the rear are torque to yield style bolts and should not be reused (90nm + 90°). The front bolts are ok to reuse after cleaning (200nm).
- You may not post replies
- You may not edit your posts
Forum Rules
