Results 1 to 9 of 9
Thread: Left parking light stays on after locking car
    Mar 2011
    sydney
    2 times in the last couple of weeks where the left Parker lights and the left behind lights stayed on after turning off the car and locking it with remote. Anyone experienced this problem? Turning on and off the car fixed the problem. Turning the lights off auto did not fix the problem. Anyone experienced this? Car was serviced a couple of weeks ago without issues.
    Jun 2011
    Sydney NSW
    Quote Originally Posted by hippyhippy View Post
    2 times in the last couple of weeks where the left Parker lights and the left behind lights stayed on after turning off the car. Anyone experienced this problem? Turning on and off the car fixed the problem. Turning the lights off auto did not fix the problem. Anyone experienced this? Car was serviced a couple of weeks ago without issues.
    Sounds like the Europe thing where when you park on an unlit load you must have the off-side parking lamps lit. This is done by leaving the turn indicator on left to light up just the left parking lights, and right to light up just the right parking lamps.
    It just means that you need to make sure that the turn signal indicator is in the middle
    Mar 2011
    sydney
    I think that might be it. But if this stays on. Won't it drain the battery?
    Feb 2009
    Sydney, Australia
    Yep - what wai said! At least in my previous 9N3 Polo GTI and my current MK6 Golf R, the car will also be beeping at you after you remove the key from the ignition when you've got one of the indicators on. This is to remind you that one side of the parking lights will stay on.
    The modern VW's are smart enough to turn it off eventually so the car will still start.
    But still... don't leave the indicators on when you turn off the car! lol
    Aug 2007
    Perth WA
    Parking light feature. Assuming you have parallel parked and had your indicator on as you got out of the car. Turn your indicator stick off and the lights will not be on
    '04 BMP MkIV R32 #144
    search getnew
    Aug 2007
    Perth WA
    LOL 3 replies in a min, must have all be typing at same time hahah
    It doesn't leave any of the dashboard lights turned on like you would have if your turned your parkers on via the headlight switch. So no, it's designed to do that. Won't drain the battery, well not unless you leave it for like a month....it's only 2 low-voltage globes
    edit; as Corey said, it might turn off automatically anyway... the interior lights turn off after about an hour if you leave a door open. Read the manual, you might find some other surprises if you've only just got the car
    search getnew
    Adelaide hills, SA
    Is there a sound, when you remove the key from the ignition? (wife drives the Tig 99% of the time, so I didn't check, but my T5 let me know with the buzzing sound that I left the parker on)
    More info for you in this thread. http://www.vwwatercooled.org.au/foru...rks-33622.html
    Mar 2011
    sydney
    There is no sound after I turn off the car. The lights also don't turn off after an hour cause they stayed on for at least 2 hours the last time I didn't notice. Thanks for all the help. Appreciated.
    Jul 2011
    Berry NSW
    This is a very useful feature in certain circumstances. Like when parked on a dark narrow road.
    1. Flick the indicator stalk up or down before turning off the ignition.
    2. Turns on just the parking light on the side the indicator stalk indicates.
    3. Sounds a brief beep just as you turn off the ignition and before you open the door. (If you are quick you might not notice)
    I have used this on a number of occasions. Very useful and doesn't seem to have any impact on starting after several hours.
