Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Just purchased a 2012 132TSI Pacific!
    Jul 2018
    The car has an annoying vibration when cruising and gently touching the accelerator.
    It only does it at around 30 to 60kph and when its in high gear and RPM is about 900 to 1200 give or take.
    I've since found a thread about it on the USA/Canada clubs which says its normal and common to all the 6 speed automatics. They fixed it over there with a software patch which keeps the RPM's higher to stop this happening.
    Whats the status here? Anyone have any experience with this issue?
    This is the long thread about exactly this issue here:
    VWVortex.com - Concern about 2012 Tiguan auto transmission
    Jul 2018
    Here she is on her first drive to Queenscliff in VIC.
    Just purchased a 2012 132TSI Pacific!-20190707_171909-jpg
    Got some 18" Kingston Wheels for it coming soon!
    I'll keep the 16's for the snow.
    Erskineville, NSW
    Quote Originally Posted by Yapa View Post
    I will get a quote from VW to check "timing chain tensioner" and the carbon buildup too. If it's around 1K to do then its worth it I know.
    I wouldn't let a dealer near it. Their lack of enthusiasm and pulling a price out of thin air should be a warning.
    Jul 2018
    So I've had the chain and tensioner replaced.
    The car build date is Nov 2011, engine is 06.11.11.
    The old tensioner part number was 06K 109 467 IT MR7, which appears to be the latest revision?
    I wonder if the previous owners had replaced it, no history of this by VW (serviced by only one VW dealer since new)
    Jul 2020
    Is there any known way to check if a Tiguan has the updated tensioner? I know VW replaced the faulty tensioners after 2012, but I just bought a Pacific MY13, which was released in 2012 and was wondering if it was still an issue. Is there an engine build date or anything that might indicate the update?
    Jul 2020
    Just found this. It's not conclusive but might be a guideline for future purchases. From comment #17.
    DEFECTIVE timing chain tensioner in 2.0 TSI engines | Volkswagen Owners Club Forum
    Dec 2022
    North Balgowlah 2093
    Older Tiguan
    At least make sure you have the latest revisions of the timing chain tensioner. To check and replace it is close $1000 but still better than kill the engine. Any VW mechanic should be able to do the job.
    We’re wrecking Octavia RS of the same age with the same engine because of failed tensioner.
    Mine is a 2012 TSI 132 manual AWD as well. Currently at 245k km.
    Timing chain tensioners give a slight tick when revs drop and fair bit of oil use. About to get some engine work as I want to keep it.
    Including tensioners and chain.
    Wondering if new pistons or just rings is worth doing.
