Results 1 to 10 of 16
Thread: Intermittent Parker lights - faulty connectors???
    Wondering if anyone else has come across issues with the front parker lights (side lights) coming up with a warning in the MFD and not illuminating.
    I've had on/off intermittent faults coming up for the last couple of months. I asked the VW service manager and he grumbled about the bulbs/connectors that VW use are the problem and that he could supply new bulbs that would probably fix the problem.
    Anyway when I get the fault, the parker light doesn't light up so I tap the outside of the light housing and the parker light comes on . So it's definitely not a broken bulb.
    I've taken the bulbs out and polished the connectors but still didn't fix the issue.
    Intermittent Parker lights - faulty connectors???-009-jpg
    Intermittent Parker lights - faulty connectors???-011-jpg
    Intermittent Parker lights - faulty connectors???-014-jpg
    Anyway its been annoying me for long enough so I figured I'd ask if anyone else has seen this issue.
    Adelaide hills, SA
    Try replacing the T10 globe.
    Maybe I ought to try and find some LED globes while I'm at it....
    Whyalla SA
    Yep, I've got the exact same issue on the RHS of my 2010 GTI. Definitely not the globe as it comes back on. Would like to know the fix, agreed, very annoying
    Quote Originally Posted by GoddyB View Post
    I am glad to hear that I'm not the only one with this issue. I'll certainly keep you posted on the "fix" once I get the issue resolved. Been to a dealer and an independent so far and nobody knows exactly what the problem is.
    Globes are cheap so I probably will just replace first off and see if this resolves the issue but it has me puzzled as the globes still work - they just fault every now and then (getting more frequent).
    Whyalla SA
    It's happened to me twice, first time was about 2 months ago then again 3 nights ago. First time it was raining but the other night no rain but a moist dewy night, wondering if moisture has something to do with it???
    Dec 2008
    Sydney/Canberra
    You need to tighten the terminals in the globe socket. They lose tension and spread apart over time.
    It's a very common side-affect of those 5W wedge globes. Happens on all cars that run that style of globe.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Quote Originally Posted by Umai Naa!! View Post
    Thanks! Sounds like a logical cause. I'll give it a shot tomorrow.
    Well got out with a small screwdriver and with some gentle persuasion I tightened up the connectors this morning.
    Before:
    Intermittent Parker lights - faulty connectors???-005-jpg
    After:
    Intermittent Parker lights - faulty connectors???-008-jpg
    Turned the ignition on and it still faults (had to tap the lens to get the parkers to turn on) .
    Dec 2008
    Sydney/Canberra
    Have a close look at the globe.
    The bad connection can cause the globe to fail.
    '01 Beetle 2.0
