Hi suparockin,
That looks fantastic. I hope it sounds as good as it looks.
My ambitions are slightly simpler to start with.
Is there already a sub woofer in a base spec 118 TSI?
Is there an easy audio feed in the rear if I fit my own amp and box sub?
Can I just split off from a rear door speaker feed and if so where's the easiest point to tap into it?
Does the head unit have a line out for a sub?
What's the easist route to run cables front to back?
Where's the easist point to get a power cable through the firewall?
If there's already a thread on the subject please point me at it.
The only audio threads I could find seem to focus on changing the head unit.
Thanks for any help.
- You may not post replies
- You may not edit your posts
Forum Rules
