Page 5 of 5 FirstFirst ... 345
Results 41 to 46 of 46
Thread: Installing Sound System in Tiguan (Audio upgrade)
  1. #41
    Oct 2012
    Augustine Heights, QLD
    Quote Originally Posted by Ramee View Post
    Just contributing my experience with Tig sound upgrade. I have a Audison bit ten as the LOC & processor between AMP and RCD510 and I am happy to say it is well worth it. Key point here is the tune-ability of the Bit ten. It has all the filters and 32 band equalizers in every channel and someone can tune it to improve the sound quality to a remarkable level. For proper tuning you may use a professional audio spectrum analyzer or there are some good android apps that can be used with good success. Simply download a pink noise sound clip from net and play it through the RCD510 while visualizing the output graph through an analyzer. If your sound system is perfect you should see a flat graph through whole bandwidth (will never happen in real life) but you can try to get the graph flat as possible by tuning Bit ten equalizers and crossover filters.
    Hey Ramee, So I ended up getting a good deal on a Bit Ten that I intend to install this weekend. Did you do it yourself? Does anyone know if its okay just to daisy chain the power and ground from the amp?
    Can't wait to have a tinker with it all set up, the tuning ability of this thing looks incredible!
  2. #42
    London
    Quote Originally Posted by Aztech View Post
    Hey guys,
    I know this is an old thread now but I'm just in the process of upgrading the audio on my tig. I have used the front speaker wires from my RCD510 into a line level converter into a 4 channel arc ks300.4, from there I am running 2 channel to a set of Alpine splits in the front and bridged the other 2 channels to run a 12" arc sub in the boot space.
    It sounds decent enough, but I am thinking that the cheap Autobarn line level converter might be the Achilles heal of the whole system. I have looked at those Audison Bit Ten/Ones as the OP put in there system but fear the wife might not see it as a good investment.
    Does anyone know of a cheaper alternative that would be better than the LOC even if not a good as a Bit Ten?
    Would finding someone with a Vagcom and changing the level output on my RCD510 to the Dynaudio output help at all?
    Thanks,
    Aztech
    As mentioned many amps have high level inputs from which to covert into pre-outs but if you're looking for a cost effective Convertor compared with a bit ten have you seen the LCQ-1 from Audiocontrol?
    http://http://www.audiocontrol.com/t34/17612/712451/OEM-Integration/LCQ--1----Six-Channel-Line-Output-Converter-with-Equalization-and-AccuBASS.html
    There are a few on ebay too.
    2011 Candy White Tiguan R Line 170 TDI DSG | Pan roof | Park assist & RVC | RNS 510 | MDI | LED's | 20" RS5 Wheels| Bi-xenons & AFS | Front & Rear footwell lights | Door warning & puddle lights | Mirror puddle lights | LED Tail lamps | Eibach Pro-Kit Springs
  3. #43
    Oct 2012
    Quote Originally Posted by Naresh View Post
    Thanks Naresh, I did actually end up getting an LCQi and then found a Bit Ten D on Gumtree for $120 so I have both at home now lol.
    I will be putting the LCQi back up for sales so if anyone's interested let me know.
  4. #44
    Jun 2013
    Yes. I got power from the wires coming for the Amp as well. I think Bit Ten has internal regulators so bit of voltage fluctuations does not matter. Bit ten has signal sensing power up too and output a remote signal for the Amp. So no issue there. I have bit ten mounted on the Amp using velcro and use short RCA cables to connect five channels to the amp. Enjoy your Bit Ten!
    2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
    Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
  5. #45
    Oct 2012
    Thanks Ramee, got power from the amp, piece of cake and working fantastic. Took me some messing around to get the sub working well but now I have the sound difference is incredible. I can't rave about the bit ten enough, even my partner who never notices anything commented on how good it sounds now.
    I didn't realise you needed the CD that came with it for the de-equalisation function so I've contacted Audison to see if they can provide me one, but even if I can't the PC interface is fantastic and I am more than happy with the results I'm getting with that.
    Next project will be to get rid of the sub box in my boot thats taking up half the space. Thinking of maybe building something to go next to the spare under the boot floor.
  6. #46
    Jun 2013
    Good to hear mate! Also try to get some proper tuning done and you will be surprised. Many sounds (instruments) you never realized that existed in the song become crystal clear when proper tuning is done.
    Don't bother about that CD with de-eq because bit ten could not find any pre eq from RCD 510 when I tried it.
