@Peedee61: Of course anything is possible - so there is a finite probability that the internal circuits in the ECU have gone pear-shape. However, I suspect that the probability of the problem here being a component failure external to the ECU is far greater!!
I'm not sure which particular engine is installed in this car - but it's quite likely that G28 is a Hall-effect sensor (i.e. this engine does NOT use an inductive type speed sensor). My assumption can be confirmed if the sensor has a 3 x pin connector.
The general set-up for a Hall effect sensor is like this (I thieved the picture from the web) :
As you can see- these senors use an external power supply (labelled "Vcc" in my diagram). In your engine, this power-supply is 5Volts - which is generated by the ECU. There is also a ground pin for the 5Volts which is different to car earth and the remaining pin is the pulsed voltage that is the speed signal to the ECU.
I'm not sure about this particular G28 sensor - but normally on these 3 x pin connectors:
- 5 Volts = pin #1
- Signal = pin #2
- Earth = pin #3
The best way to check the operation of this sensor is with an oscilloscope because it will show how the voltages change with time - but it's unlikely that you will have access to a scope. There are a number of You-tube videos that describe how to use a multi-meter to check the operation of Hall-effect sensors
So - the way to check the wiring for this sensor is to grab a multi-meter and first measure if the +5Volt power supply is present at the 3 x pin sensor connector. It's unlikely that the +5Volt supply from the ECU is faulty because this same power supply is used for other Hall-effect sensors on the engine -but it may be absent at the connector on this particular sensor.
The other possible reason for this fault could be the condition of the air-gap between the sensor and the toothed wheel. Shine a torch onto the gap and check that it's clean and free from detritus.
