Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 77
Thread: Huge vibrations in tiguan!! Help!!
    May 2009
    Perth WA
    I had a set of Pirelli once that were not completely "round" and they caused similar issues. The shop spent hours working it out and in the end got new ones and so carefully fitted them and all fixed.
    Feb 2010
    Camden NSW
    Thats the problem goodfella....knowing who is reputable. Also dont want to have to go through all the hassles again... explaining it all, and running the same experiments aaarrrgh!
    However you are correct, and I am more than happy to pay money to a place that can get it right...but where is the big question??
    So many dodgy places around- even those with branded names on them cant get it right!
    2018 Ralyee Green RS wagon. Fully optioned.
    Previous vehicles:2015 Volvo V60 Polestar (my one detour from VW/Skoda!)
    2013 Platin grey RS wagon / 2012 White Polo GTI / 2009 Black 125 Tiguan
    Adelaide hills, SA
    Most tyre places don't employ mechanics, tyre fitter can be trained in a 1/2 day to fit the tyres, so it is understandable that they are not able to help if there is something wrong. Also guys if you need a wheel alignment ask the tyre place and verify before you go to them, that they have the data for wheel alignment for the Tiguan because chances are that they don't.
    After removing tyres make sure that the wheel bolts are properly tensioned;120Nm in diagonal pattern. Otherwise you can get another vibration from the brake discs that can distort, if the tension is greater and uneven.
    edit: when you removed the wheel always correctly tighten the wheel before you let the wheel touch the ground! Check the wheel bolts tension again after 50km.
    Feb 2010
    Camden NSW
    Thanks transporter,
    I am not sure what tension they have applied when doing up the wheels...or even if they have used the correct bolts etc...
    I didnt notice it at first...so could the beading be causing the issues? Does this distort over the course of a few thousand kms and get worse?
    Now my whole arm shakes when I go over 95kmh!!!
    Jun 2009
    Quote Originally Posted by tigger View Post
    Thanks transporter,
    I going to go with the wheel bolts being the problem rather than the headligning.
    Make sure whenever you take your car to get done that you specify 120Nm for the bolts and make sure they are long enough.
    Adelaide hills, SA
    Thanks transporter,
    Well, as some one above suggested put the original wheels back on, do them up correctly, take it for test drive and let us know.
    Yes, it takes 2k-5k km's to show up.
    Nov 2008
    QLD
    Just swap your wheels back tigger - easy, and then you can either stop worrying and go and wrestle with your tyre guy, or really start worrying!
    If it is still there, I probably wouldn't be putting the aftermarket wheels back on and driving it into my dealer for a claim.
    Feb 2010
    Camden NSW
    well!!! for all interested in the update...
    After more than two hours of time again at the tyre place, I have lost patience. They did all number of things etc and tried to sort it out. Things such as rebalancing, stripping and refitting etc etc
    I had some of the guys acting rudley to me, as if I had nothing better to do than waste their time..AAARRRGGGHHH!!! I had work to do today which cost me over three hundred dollars...
    Anyway, as you have all suggested, the original wheels and tyres are back on, with the original bolts.
    I drove it on a long stretch of perfectly smooth straight freeway in the country, way past the required speeds and guess what???? NO PROBLEMS AT ALL!!! In fact they were perfect!
    So I reckon that the Advanti wheels have somehow either gone out of shape, or the tyres have distorted over the last few thousand kms, OR as suggested...THE BOLTS ARE INCORRECT causing the wheels to sit in a wrong manner etc.
    So now they have to "get back to the wheel supplier" and get in new tyres until it is all sorted.
    I hope this does not go on too much longer. I might just stick to the originl wheels and forget about it...how disheartening
    Adelaide hills, SA
    Hey Tigger,
    do you have a picture of the wheels? It would be good to post it here. If you already didn't.
    Nov 2008
    QLD
    Hey Tigger,
    Yeh let us know what you have. But it's a good result - at least it's NOT the Tig!
