SOLUTION - HANDY TIPS TO REINSTALL
I have just put ours back in, didn't take too long. Key points are:
- note that the small plastic pivots dont go into the sides of the rear console or into holes, they go into curved rails in the sides of the drop out mechanism towards the bottom. Its relatively easy to pop them back into those rails, though also easy to go too far and actually be further in than the rails. You might need a torch to see the rails well enough unless your car is outside with heaps of light.
- the other connection points b/w the drop out mechanism and the cover is two hooked projections in the centre of the drop out mechanism that must click into two points in the centre of the cover. Effectively those hold the cover to the drop out mechanism, more so than the rails above. Both are horizontally in the centre of that cover, one at the bottom and one about half way up.
- the challenge is getting the small pivots into the rails as well as getting the two hooks to properly click onto their mounts on the cover. I have found that when I have focussed on getting the pivots into the rails first, it has proven difficult to get the hooks to lock into their mounts propperly. So the best way is to concentrate on getting the hooks locked on first - there should be an audible click and then fine tune fiddle to get the pivots in their rails
Hope this helps.
