Results 1 to 8 of 8
Thread: How to re-glue side mirror?
    Jan 2009
    SEQ
    Question How to re-glue side mirror?
    The driver side read view mirror on my 09 Tiguan TDi came un-stuck.
    I was driving along and the mirror started shaking horribly. Managed to pull the actual glass piece off before it fell and shattered. So it's all in 1 piece and I need to re-glue it somhow.
    Our Tig has a heated mirror.
    Will araldite be OK to use given it's a eating?
    What glue should I use to re-attach it?
    Jul 2010
    Robina Gold Coast
    i think i would be using Stixaflex adhesive ,but you will also need some masking tape to hold it in place for a few hour till it sets ,
    Jan 2009
    SEQ
    Quote Originally Posted by ian View Post
    Thanks. You mean this stuff: Sika 310ml Sikaflex 11FC Grey Polyurethane Adhesive Sealant
    Jul 2010
    Robina Gold Coast
    Clear would be better but the grey is ok as its not seen once applied ,only use a few dabs on the backing and make sure its clean Alcohol or Metho
    Jan 2009
    SEQ
    I ended up getting Liquid Nails for glass: Selleys 310g Liquid Nails Mirror Metal And Glass | Bunnings Warehouse slightly cheaper. Worked well. Mirror seems pretty well stuck on.
    Jul 2010
    Robina Gold Coast
    Stikaflex is used to install after market body panels ,once it sets it will never come off ,
    Jul 2013
    #ADL, SA
    Quote Originally Posted by TonyTA View Post
    Same problem here...
    Wondering if your heating function is working okay to defrost the mirror?
    And how much of the Liquid Nails did you use (e.g only around the edges, over the entire surface, really thin film on both the mirror glass and the side mirror)?
    Thanks.
    Adelaide hills, SA
    Do it right and use double sided tape. I’ve used 3M brand on our 2010 Tiguan 5years ago and it’s still strong.
