You need to turn off the cold bulb diagnostics or get resistor packs to trick the BCM into thinking your bulbs are not out.
Or you could also switch your globes to "CAN BUS compatible LEDs"
Hi guys
anyone of you have got these fault code 01495 and 01499
I have been getting these code since I change the halogen from light bulbs for Led bulbs .
So, when I switch on the night light sometime I got these error.
Thanks in advance for any advice.
MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
Genuine VCDS HEX-NET and VCP Pro
Ok copy that. So you know how to turn off the cold bulb diagnostics.
What scan tool do you have, VCDS, ODB11 etc? it will depend on your BCM part number on how to turn it off.
Hi MIG
I use VCDS but I don’t know the BCM part number.
I am not and expert with this electronic cars. But I do as much as I can. 😺
This is the products specification 7
input wattage 36 watts
operating voltage DC 12-24V
luminous Flux 3800LM/bulb
color temp 6000K
light source custom flip chip
VW Tiguan 2016 S
If you do an autoscan with VCDS and post it, we can work out what needs to be done.
VW Tiguan 2016 S
Here are the fault codes with description. I hope they work MiG . See ya
VW Tiguan 2016 S
