Results 1 to 10 of 10
Thread: Hood release - please help
    Aug 2017
    Sydney NSW
    Hi everyone,
    I just went to pull the hood release lever on the passenger side of my Tig then a weird thing happened, the handle pulled all the way back but the hood never popped up. Now the handle is stuck in position and it feels as though all of the tension has gone out of it.
    Has this ever happened to anyone here? How do I open my hood now?
    MY11 Tiguan 125TSI | 4Motion | DSG | APR Stage 2 | GolfR IC | HF turbo outlet + throttle pipes | CAI | 3" DP
    Ceres_mining_co's Tiguan build
    Jul 2010
    Robina Gold Coast
    Quote Originally Posted by Ceres_mining_co View Post
    Hi everyone,
    Could be the cable has snapped or detached from either end , might have to remove the kick panel hopefully its that end you can then use a pair of plyers to pull the cable to relese the bonett , could be when you had all the front off the cable wasn't replaced correctly ?
    Aug 2017
    Sydney NSW
    So I took it into the dealer (had my 120k service done last week) and they opened up the trim in the passenger footwell but it was connected at that end so... it looks like they are going to be breaking into the engine bay piece by piece...
    Ooh that's no good .. they usually break off on the inside i.e. the lever's teeth shear off the female section.
    Hope they sort it out for you.
    RS
    R
    Dec 2008
    Sydney/Canberra
    Pretty easy to get the bonnet open on these, if the cable has failed.
    It may cost you a grille badge though.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Aug 2017
    Sydney NSW
    Quote Originally Posted by Tuan View Post
    They sorted it out free of charge, just in time for the long weekend!
    Aug 2017
    Sydney NSW
    Quote Originally Posted by Umai Naa!! View Post
    How do you do it?
    Aug 2017
    Sydney NSW
    Quote Originally Posted by ian View Post
    It looks like the cable did in fact come off at the kick panel end, I couldn't figure out how to take off the trim so I left it up to them. I think you're on to something, when the headlight came off perhaps the cable shifted when the tension went out of it then when it tensioned it again it moved it out of position.
    Way to go
    RS
    R
    Jul 2010
    Robina Gold Coast
    Your lucky. They didn't charge you. But it was a major drama and your right for the long week end.
