I have same siystem, originally install the kafatech mic in the overhead position worked fine then upgraded the the RNS 510 firmware to accept voice control, tried passing kafatech thru the rNS phone would work but voice control was useless upraded mic to OEM , voice control ok but phone useless. ended using both mics kufatech to kufatech ,oem to RNs510 , mounted 2nd mic (kufatech) in rh click in panel above 510 . had to put series of small holes in panel. the back of the panel looks like it has been molded to accept the OEM mike
Ted Hagstrom
2009 VW Caddy, Whte, TDi, DSG
2009 Tiguan, silverleaf, 103Tdi ,auto, Comfort pack, leather, fogs, Rns510 with RVC
