Results 1 to 10 of 12
Thread: Help - rear parking sensor
    Nov 2009
    Northern NSW
    Mrs recently reversed into a palm tree, no damage really except the drivers side rear parking sensor copped the burnt of it and had a small piece of bark wedged in b/w the sensor and its thin rubber housing. After that it has been 'stuck on' - so whenever the parking sensors are engaged, its convinced there is somethign we are getting close too and is relaying the appropriate noises. I think the sensor is emotionally damaged from the experience.
    I have climbed underneath the car and with some fiddling removed the sensor (its quite easy), cleaned it, removed the piece of wood and put it all back together. It looks the goods, no obvious problem at all, but has made no difference - sigh.......
    I have checked the manual but couldn't see anything on resetting or the like, but I haven't as yet tried checking thru the MFD.
    So not sure whether its just a reset type issue or whether I need to replace the sensor or more than that. Be nice if its just a reset, but suspect may be more of a problem than that.
    Any clues/suggestions be much appreciated.
    Tiguan TSI Catalina blue, Manual
    Sep 2010
    QLD
    The same thing happen with my C-Class, I think a stone chip might have hit it, found a slight scratch. It just refuse to work, gives me two red line in the visual. I think you need to replace the damaged sensor.
    Nov 2009
    Northern NSW
    thanks, so did you replace yours and that fixed it?
    Adelaide hills, SA
    Quote Originally Posted by jimbomort View Post
    Borrow one from the front (if you have) and see if it makes any difference.
    Jul 2009
    Emerald , QLD
    Hi,
    "obviously didn't work this time either - or was it a computer PEBKAC error.
    Ted Hagstrom
    2009 VW Caddy, Whte, TDi, DSG
    2009 Tiguan, silverleaf, 103Tdi ,auto, Comfort pack, leather, fogs, Rns510 with RVC
    Sep 2010
    QLD
    Yup, worked straight away. The sensor itself is pretty cheap.
    Nov 2009
    Northern NSW
    transporter - good suggestion, I'll try with one from the front and see if that works, and likewise swap it with and see what that then does to the front reading
    99reza - thankls for the confirmation and thats nice to hear it was realtively cheap, hopefully VW will be the same
    Sep 2010
    QLD
    If you can change the sensor yourself please do so. I almost fell of my chair when they gave me the invoice. Sensor cost $185 (for the whole array, not just one), labour $400!!!
    Adelaide hills, SA
    Quote Originally Posted by 99Reza View Post
    Why did they replace whole array? Was all of them broken/faulty?
    jimbomort before you test it, check if you can buy individual sensor and if not, ask why? The sensors could be coded together (there could be communication between the sensors in bumper bar and it could be the reason why they needed to be replaced as an array)
    Jul 2009
    Emerald , QLD
    The array is wired in one piece. I Fitted afterMarket, involves removing rear "bumper" . need to be very careful to break any clips particuarly on the rear wheel arch trim ( not really designed to be removed ),
    Ted Hagstrom
