Results 1 to 6 of 6
Thread: Help diagnosing misfire / stumble - stock 125TSI
    Nov 2012
    I was wondering if anybody can assist advice on trouble shooting an issue I have with a 2008 manual 125TSI Tiguan with 85,000kms.
    The car developed a misfire or more specifically a stumble from 2000 RPM to 3000RPM only on light throttle. However the car idles perfectly and pulls like a train with no misfire at WOT. The issue only occurs at light throttle only. The car is 100% stock.
    The car showed the following codes:
    _____________________
    Address 01: Engine (CAW) Labels: 06J-906-026-CAW.clb
    Part No SW: 06J 906 026 AA HW: 06J 906 026 D
    Component: MED17.5 3171
    Revision: A7H06--- Serial number: VWX7Z0HN3NQ7UQ
    Coding: 04230003180F0160
    Shop #: WSC 01324 785 00200
    VCID: 69F75865409FA95623D-803C
    3 Faults Found:
    000768 - Random/Multiple Cylinder Misfire Detected
    P0300 - 000 - - MIL ON
    Freeze Frame:
    Fault Status: 11100000
    Fault Priority: 0
    Fault Frequency: 13
    Reset counter: 255
    Mileage: 83568 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 11:23:04
    Freeze Frame:
    RPM: 2757 /min
    Load: 31.0 %
    Speed: 18.0 km/h
    Temperature: 29.0°C
    Temperature: 20.0°C
    Absolute Pres.: 1000.0 mbar
    Voltage: 14.224 V
    000770 - Cylinder 2
    P0302 - 000 - Misfire Detected - MIL ON
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 13
    Reset counter: 255
    Mileage: 83568 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 11:23:04
    Freeze Frame:
    RPM: 2757 /min
    Load: 31.0 %
    Speed: 18.0 km/h
    Temperature: 29.0°C
    Temperature: 20.0°C
    Voltage: 14.224 V
    000772 - Cylinder 4
    P0304 - 000 - Misfire Detected
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 83797 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 17:39:38
    Freeze Frame:
    RPM: 1081 /min
    Load: 32.5 %
    Speed: 13.0 km/h
    Temperature: 50.0°C
    Temperature: 36.0°C
    Voltage: 14.097 V
    Readiness: 0000 0000
    __________________________________
    I cleared the codes and changed all 4 spark plugs and coils and it improved the issue significantly - however it has not fixed it totally.
    The stumble is starting to come back after 100kms driving. The engine light has come on for a second time with errors P0301 & P0302 (misfire cylinder 1 & 2).
    Does anybody have advice on what to try next? or where to get quality trouble shooting information?
    Thanks in advance
    Nick
    Jun 2013
    Could be an Intake valves carbon build up issue..
    Intake valve carbon cleaning for the 2.0TFSI and 4.2FSI.
    2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
    Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
    Nov 2012
    Update on the issue. I cleaned the maf sensor with carby cleaner and it has significantly improved the stumble/misfire.
    Sep 2010
    Brisbane, Queensland
    I posted a similar thread, 2500-3000 RPM stumble/hesitation on light throttle. I cleaned the MAF, seemed a little better, but I think I may change the plugs as well.
    Sep 2010
    Also - just had my 60k service done, but spark plugs were not changed. I see mixed reports on whether these should be done at the 60k?
    Feb 2013
    Perth, WA
    I would have thought that plugs would be good for 100k on a stock engine.
    MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
    MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
