Results 11 to 20 of 31
Thread: Haldex Upgrade - Controller Installation Guide + Oil Change
    Quote Originally Posted by Ramee View Post
    It is not the filter. What you are referring to is the Haldex pump. For this version of Haldex there is no replacement filter as far as I know. But actually there is a filter on top of the Haldex unit above the Haldex pump. But this is usually not replaced.
    Ah well I don't want to be replacing that one then.
    This is somewhat relevant to Haldex so thought I just add this to the thread. Also got few pictures of controller disassembly as well so Tigger73 can use in the guide if guide missing few pics.
    Haldex Pump
    This is not very important but I disassembled the pump as well so I'll post some pictures of it too.
    These tiny little pistons pump Haldex oil to create hydraulic pressure.
    Thanks Ramee.
    I've "borrowed" a couple of the pictures to add to the write-up.
    So do you disassemble parts of your car on the weekend just for fun?
    Jun 2013
    No! these are old pics I took when I did my Haldex service. Thought I just post them as you asked about the filter and pump.
    2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
    Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
    Sep 2011
    Townsville, Nth Qld
    Quote Originally Posted by Umai Naa!! View Post
    No filter on the Gen4 Haldex.
    Good write-up, by the way. I fitted a Haldex Blue for a customer, and it's pretty much spot-on.
    Only thing I did differently was use a Tom Thumb fluid pump bottle instead of the syringe. Takes less than a minute to fill the Haldex. I always give it a few pumps through, before I put the drain plug back in, just to give it a bit of a flush through.
    Mine was "Blue" as well - is there any difference between the blue and silver performance wise?
    2011 147TSi 7spd DSG Reflex Silver, 18" New York Alloys, Leather with MDI, ECB Nudge Bar, Viezu Tune (Work in Progress), Eibach ProKit Springs, SuperPro Poly ALK & Rear Trailing Arm Bushes, H&R 26mm Rear ASB and Whiteline HD Adjustable End-Links, VAR Design 3" Downpipe, Sprint Booster, Auto-Polar FIS+ Advanced Module, GTI Sports Pedals, Flappy Paddle Strg Wheel, LED fogs as DRL, chrome blingy bits
    Quote Originally Posted by Tiggy1 View Post
    I thought the blue ones were for Gen 2 controllers..... but I could be way off track.
    Dec 2008
    Sydney/Canberra
    Blue one in question, was fitted to an R36, which is a Gen4.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jun 2013
    Actually there are two versions. Functionality is same but one is stealth (your one) and other is normal (blue) version. But HPA only selling stealth setup for Tiguans. There are other suppliers like HP who sell blue version for the Tigs though. Check stage 3 Tiguan build thread.
    Sep 2011
    Townsville, Nth Qld
    Ah cool - makes sense. I got mine from the States ( can't remember exactly where TBH), but I remember giving them my Haldex assy part number to make sure it was right!
    Saw this Gen4 Haldex filter on Nuespeed: Haldex Gen 4 Filter Replacement Kit
    Also available from a couple of other places including HSTuning: HS Tuning - Haldex Gen 4 Filter Replacement Kit - HALDEX.111358
    Looks like it's suitable for the Tig. Maybe next oil change....
    Sep 2011
    Townsville, Nth Qld
    Cool - well spotted
