Results 1 to 8 of 8
Thread: GTI springs on Tiguan
    Sep 2009
    Perth
    Does anyone know if you can put GTI springs on a Tiguan? Will it lower the car?
    I think you'll find GTI springs will drop it too far and you have to replace the shocks as well. Depends what look you're after or what you're trying to achieve.
    Both Eibach and H&R do lowering springs for Tigs and will drop between 35 and 50mm. You can still use the stock shocks. Quite a few Tigs are running these with varying reports.
    Some people have reverted back to stock and some prefer the firmer ride. Comes down to personal preference and where you do most of your driving.
    Jun 2009
    A lot of the Tig's on vortex are using GTI springs and they are working fine for now but not sure how the shocks would hold up, probably better to go with dedicated Tiguan springs.
    London
    Hi do you know what these varying reports consist of? Do they include any negative effects such as mechanical problems or is it down to how the car feels afterwards? I was considering Eibach sport springs for the later this year as they give a nominal 25mm drop. (from what I was told that is)
    2011 Candy White Tiguan R Line 170 TDI DSG | Pan roof | Park assist & RVC | RNS 510 | MDI | LED's | 20" RS5 Wheels| Bi-xenons & AFS | Front & Rear footwell lights | Door warning & puddle lights | Mirror puddle lights | LED Tail lamps | Eibach Pro-Kit Springs
    Quote Originally Posted by Naresh View Post
    There's been a few people revert back mainly due to stiffer ride from lowering springs.
    Again like I said it's personal preference and probably also depends on what roads you drive on if the stiffer springs are going to be a pleasure or a pain in the backside - literally.
    Adelaide hills, SA
    I agree and in Adelaide it would be pain, if you like a quiet car. Mainly because of our third world country road condition, it's like after the war around the Flagstaff Hill and down south, I can see the grass growing in the bitumen and when raining it gives you impression that you're driving through the river beds. It will be harder and harder to pick up the track for the tour down under as the time progresses.
    Sep 2009
    Perth
    Thanks for the feedback. I've got a pair of springs from my GTI sitting around, hence the idea. I'll have a look around vortex.
    Sep 2011
    Townsville, Nth Qld
    Hi Bakks,
    I put the Eibach Pro-Kit springs on mine about 18 mnths ago (leaving original shocks on). Main reason (in my case) was to get rid of the jittery ride over our crappy roads (you think yours are bad Transporter - you should see ours ). They are a progressive rate spring, so the theory was that they would be softer initially than stock springs to soak up more of these small bumps, but firm up more on the bigger stuff. I'd say I am 80% happy that they achieved this aim. The added benefit is that because of the slight lowering and stiffer ride when cornering, the little beast handles like it is on rails
    My original shockies appear to be holding up OK (done about 18000km on Eibach springs) however my front upper strut mounts have failed prematurely (they are to be replaced under warranty, so possibly a common fault). I also have a rattle/knock from RH/rear somewhere, which could be something in the rear suspension but is yet to be determined. I'm sure it was there before getting springs changed, but has steadily been getting worse. Hopefully they can find it once they have replaced the strut mounts up front to get rid of the noise from them!
    2011 147TSi 7spd DSG Reflex Silver, 18" New York Alloys, Leather with MDI, ECB Nudge Bar, Viezu Tune (Work in Progress), Eibach ProKit Springs, SuperPro Poly ALK & Rear Trailing Arm Bushes, H&R 26mm Rear ASB and Whiteline HD Adjustable End-Links, VAR Design 3" Downpipe, Sprint Booster, Auto-Polar FIS+ Advanced Module, GTI Sports Pedals, Flappy Paddle Strg Wheel, LED fogs as DRL, chrome blingy bits
