Results 31 to 37 of 37
Thread: Group Buy: R-Dash LED Licence Plate
  1. #31
    Jan 2011
    Brisbane - QLD
    had a set of the R Dash arrived today. installed without the resistors, then ticked byte 17 bit 7 'license plate light w/o... [LED Light]''& unticked byte 23 bit 6 'lamp monitoring...
    drove around and the error warning came up
    then unticked byte 17 bit 7 just to try again, drove around and warning light came up again...
    mine is late 2010 built MY11. looks like i need to stick the resistor stuff..
    i have the oem license plate leds in my golf and have not seen such warning (but with uprated CECM..).
    MINI Cooper S Clubman - FWD
  2. #32
    Quote Originally Posted by nat225 View Post
    Yes it seems the later model Tiguans are really picky in terms of bulb out warnings. You'll see that most sellers have worked out that their "error Free" LED's don't work on later model Tigs as they will exclude them from the list of compatible models.
    I've had the R-dash ones in for a couple of months now (with resistors) and no issues.
    Feb 2013
    Perth, WA
    The bulb monitor is looking for around 3.8 watts of draw so adding in an appropriate resistor should do the trick.
    I've ordered some appropriate ones with some generic LED bulbs. I'll take some photo's and do a write-up if it works. It seems pretty straight forward to me.
    There are plenty of guys with MK6's doing the mod themselves with success.
  4. #34
    Let us know how it goes.
    The r-dash have some nice resistors with big cooling fins attached.
    From all reports the Tiguan is a little harder to please than a lot of other models.
    London
    My R-Dash units are are still working fine without the big resistors attached. I simply disabled the monitoring using VCDS and they have been fine, touch wood.
    2011 Candy White Tiguan R Line 170 TDI DSG | Pan roof | Park assist & RVC | RNS 510 | MDI | LED's | 20" RS5 Wheels| Bi-xenons & AFS | Front & Rear footwell lights | Door warning & puddle lights | Mirror puddle lights | LED Tail lamps | Eibach Pro-Kit Springs
  6. #36
    Feb 2013
    Perth, WA
    I believe if you have the factory Bi-Xenons then you have a slightly different CE module which is originally designed to work with LED's. This is why you probably don't get the warning. I have a friend with a 2012 w/Xenons and he just popped normal bulbs in, turned off the monitoring and it worked. But with my 2013 w/Halogen headlights using the same globes and monitoring off triggers a warning.
  7. #37
    Jul 2010
    Quote Originally Posted by Wynnston View Post
    Nope ... I've got bi-xenons and it's very sensitive on my Tig.
    MY11 Tiguan 147TSI (SOLD)
