Results 1 to 9 of 9
Thread: Gremlins in the electronics
    Nov 2009
    Wakerley, QLD
    Last night I popped out for some ice cream, locked the Tig, bought said ice cream, double chocolate, opened Tig with the key fob but the interior lights didn't turn off when starting. Left it about 10 seconds but still on
    I then noticed that the MFD was showing the outline of the car that indicates if doors are open. This didn't go away when I backed out and started driving, the interior lights remained on. I was unable to change the MFD to show other functions
    When I got home I turned it off but the lights remain on, I locked and unlocked but still the same. I started and stopped the engine a few time and it seemed to resolve
    Any one else had an issue such as this?
    Tig 125 TSI
    Black
    Comfort
    Off Road
    20s on the way
    Dec 2008
    Alexandra, New Zealand
    I've had the MFD "lock up" on the basic display of the car outline before but it always resolved itself after a start or two. Nothing other than that in my case.
    Derek
    Alexandra
    2022 R-Line Golf Mk8 in Kings Red Metallic
    Previously 3 Tiguans 2008, 2013, 2017
    Oct 2009
    Mate, it was the car saying "get out right now with that ice cream before you stain me".
    Nov 2008
    QLD
    do you have any non-OEM stuff installed? - e.g. SATNav, head unit, other audio gear, towbar etc.
    Nov 2009
    Wakerley, QLD
    Quote Originally Posted by clip View Post
    Only thing not standard on it is the rubber mat in the boot.
    Seems to have resolved itself at the moment but will be talking to dealer if it happens again
    Tig 125 TSI
    Black
    Comfort
    Off Road
    20s on the way
    Nov 2008
    QLD
    Quote Originally Posted by marcsamus View Post
    ahh, that'll be it. See the Tig has all sorts of sensors that detect non-genuine parts, inlcuding non-OEM rubber mats. These sensors sniff out this sort of thing, and of course, as they interface with the car's main ECU through the CAN bus system, it'll be getting all sorts of weird readings from that non genuine mat. Pull it out and your problems will disapear I'm sure.
    Oct 2009
    I'm actually glad that someone else has brought this up. I've noticed the same thing. When having the Satnav active, I was scrolling through to change a station on the radio and when I went to go back it skipped through to all of the normal settings except the Satnav info on the MFD.
    On another occasion, I put the car in reverse and the review camera didn't come up.
    Also, just last night, I was driving along and went to change tracks on my ipod and all of a sudden the "up" and "down" arrows stopped working!
    Things things have only happened once but if it starts again I'll be taking it back for a check up!
    Dec 2008
    I think we all need to remember that modern cars are "run" by computers and each attached accessory (such as radio, ipod etc etc etc) then has its own computer. I use a computer all day everyday for design work and even though it's one of the most reliable in the world it occasionally starts to do some funny things and I have to "restart" or something to get it all back to normal. It's a simple fact that electronics can and do get "side tracked" at times. Often I think we unknowingly create the problem ourselves by using a "sequence" of commands or failing to wait for something to switch off correctly before expecting it to something else. Generally these issues are easily fixed with a "re-boot" of some kind. The good old "switch it off, wait 20 seconds and then switch it on again" is usually the "cure".
    Derek
    Alexandra
    Nov 2008
    QLD
    Quote Originally Posted by NZTiguan View Post
    I think we all need to remember that modern cars are "run" by computers ... The good old "switch it off, wait 20 seconds and then switch it on again" is usually the "cure".
    hey, come on NZ, we're driving VW's here, not Toyota's!
