Results 1 to 4 of 4
Thread: Fuse box picture
    Oct 2010
    Fuse box picture
    Hi members, i was wondering if someone could either post a picture or send me a picture of the fuse box behind coin box?
    I had a fuse blown the other day, so i called VW roadside assist and they sent me RACV. He replaced a fuse and since that day car has had fault in catalytic converter light up (red).
    Today went to switch on and this was no longer a problem, now it's engine coolant flashing red?
    Since RACV came to look at the car i've had problems everyday.
    Did a scan and had heaps of faults. I think he might have put some fuses in the wrong place.
    Scan Results:01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    22-AWD -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 1010
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    MY10 Tiguan 125TSI /APR Stage 2
    Mackay QLD
    Pm your email address and send me your vehicle details as per the white sticker in your boot or service manual booklet and I will email you a PDF file of the fuse allocations
    Adelaide hills, SA
    125 TSI from 5.09 (also for TDI 103kW)
    Fascia 1
    Fuse, (Amps), Circuit
    F1 -
    F2 -
    F3 -
    F4 -
    F5 -
    F6 -
    F7 -
    F8 -
    F9 (5A) Supplementary restraint system (SRS) control module
    F10 (10A) Four wheel drive control module
    F11 (5A) Parking aid control module, self-parking system control module
    F12 (10A) Gas discharge headlamp control module (LH)
    F13 (5A)
    ABS/ESP system, AC system, anti-dazzle interior mirror, heated windscreen washer jets, seat occupation control
    module, transmission control module (TCM), reversing lamps, engine management system
    F14 (10A)
    ABS control module, engine control module (ECM), heated seats, power steering control module, suspension
    control module, trailer control module, AC control module, instrumentation control module, CAN data bus
    gateway control module
    F15 (10A)
    Auxiliary heater, data link connector (DLC), parking brake control module, engine management, headlamp
    direction control module
    F16 (10A) Gas discharge headlamp control module (RH)
    F17 (5A) Instrument panel
    F18 (10A) Mobile telephone control module, multimedia control module
    F19 (10A) Steering column function control module 2
    F20 (5A) ABS control module, AC system, transmission control module (TCM)
    F21 (15A) Door function control module, left rear, door function control module, right rear, multifunction control module 2
    F22 (5A) Alarm system, multifunction control module 2
    F23 (10A) ABS/ESP system, AC system, data link connector (DLC), rear view camera control module, headlamp switch
    F24 (10A) Door function control module, driver, door function control module, passenger
    F25 (20A) Transmission control module (TCM)
    F26 -
    F27 -
    F28 (40A) AC control module, auxiliary heater
    F29 (15A) Rear screen wiper motor
    F30 -
    F31 (20A) Auxiliary power sockets, cigarette lighter
    F32 -
    F33 -
    F34 -
    F35 -
    F36 -
    F37 -
    F38 (10A) Steering column function control module 1
    F39 (20A) Headlamp washers
    F40 (15A) Trailer control module
    F41 (15A) Trailer control module
    F42 (20A) Trailer control module
    F43 (25A) Sunroof control module
    F44 (25A) Parking brake control module
    F45 (25A) Heater blower motor, heated rear window
    F46 (30A) Door function control module, driver, door function control module, passenger
    F47 (30A) Door function control module, driver, door function control module, right rear
    F48 (15A) Fuel pump (FP)
    F49 (20A) multifunction control module 2
    F50 (25A) Parking brake control module
    F51 (40A) AC/heater blower motor control module
    F52 (30A) Seat heater control module
    F53
    (20A/30A)
    Headlamp washers
    F54 (30A) Auxiliary power sockets
    F55 (15A) Lumbar support adjustment
    F56 (15A) Suspension control module
    F57 (25A) Sun blind control module
    F58 (1A) Trailer warning lamp
    F59 (20A) Multimedia control module
    F60 -
    Fascia 3
    in engine bay
    Fuse (Amps) Circuit
    F1 -
    F2 -
    F3 (5A) Multifunction control module 2
    F4 (30A) ABS/ESP system
    F5 -
    F6 (5A) Instrumentation control module, steering column function control module 2
    F7 (40A) Ignition main circuits
    F8 (25A) In-car entertainment (ICE)
    F8 (25A) Voltage converter
    F9 (5A) Mobile telephone control module
    F10 (5A/10A) Engine control module (ECM)
    F11 (20A) Auxiliary heater control module
    F12 (5A) CAN data bus gateway control module
    F13 (15A/30A) Engine control module (ECM)
    F14 (5A) Engine management system
    F15 (5A/10A/15A) Fuel pump (FP), AC compressor clutch, engine management system
    F16 (30A) Multifunction control module 2
    F17 (15A) Alarm system horn
    F18 (30A) Audio system
    F19 (30A) Windscreen wiper motor
    F20 (10A) Engine management system
    F21 (10A/20A) Engine management system, fuel pump (FP) control module
    F22 (5A) Clutch pedal position (CPP) switch
    F23 (10A) Engine management system
    F24 (10A) Engine coolant blower motor control module, engine management system, engine coolant heater
    F25 (40A) ABS/ESP system
    F26 (30A) Multifunction control module 2
    F27 -
    F28 (50A) Glow plug control module
    F29 (50A) Electric seats
    F30 (50A) Ignition switch circuits
    Location Component
    1 Petrol: Engine control (EC) relay 1
    1 Diesel: Ignition main circuits relay
    2 Petrol: Engine control (EC) relay 2
    2 Diesel: Engine control (EC) relay
    Oct 2010
    Once again, thanks to all. Will go through all the fuses to see what's wrong. Will. Also be booking my 30,000km service.
    Thank you!!!
