The fuel warning comes on when the range drops to 30km.
I filled up the car the other time when there was only 5km leftwhich means the tank was almost empty; and got about 62 litres in.
The owner's manual sez ~65l. I put in ~75l when I fill up when the 'low fuel' warning comes on.
The last 10l takes forever to put in , so I assume I'm interfering with some safety device by doing so?
What is your experience in this regard?
2010 Tiguan 147TSI - Deep Black, Black Leather, Panoramic Sunroof
Goes anywhere you can imagine.
Hey canam,
Is yours diesel or petrol?
Just wondering why you would want to try and put in more than the manual states? Do you do long trips?
2018 Ralyee Green RS wagon. Fully optioned.
Previous vehicles:2015 Volvo V60 Polestar (my one detour from VW/Skoda!)
2013 Platin grey RS wagon / 2012 White Polo GTI / 2009 Black 125 Tiguan
Mine is a petrol and I have a filled about 61 liters on it.
I fill up when it gets down to 30-50km remaining. My diesel takes 60-61 litres every time, to the second cut-off. You can see the fuel up into the filler neck. Foaming does not seem to be a big issue. I once tried to trickle fill it further, and after only a couple of litres more it overflowed (yuck).
I then have a range of about 750-800km, so I can forget about refilling again for a long time, and as diesel prices aren't cyclical, I fill up when its empty, not on a Thursday![]()
TDI tiguan in the drive. ParkAssist, comfort, fogs
Service every 15,000, new fault code every 7,500km
There is NO way you can put in a addition 10lites in a tiggy. 1 litre maybe, 10 no way
I would go to a diffrent service station as you are obviously being short changed.![]()
Hi all,
What borbor, you here too?
73l easy, more than once, different filling stations. Just be patient. Takes it in in 150ml quantities.
So where does the extra fuel go? Follow attached link and read the bit about the fuel tank: http://www.vaglinks.com/Docs/VW/Misc...StudyGuide.pdf
The tank is in two parts, and I suspect the last bit - to get the fuel in the furthest half - has difficulty in burping the air due to an intricate path. Then again, it could also be stored in the expansion tank, which seems quite large.
