So I'm part way through sorting out the issues with the front sway bar and anti-lift kit.
Just so everyone's clear about what we're talking about it's the following parts:
Whiteline X-heavy duty front sway bar: BWF20XZ
Whiteline Anti-Lift Kit: KCA316
These parts were professionally fitted onto my 2011 125TSI - much bigger job than I'd attempt as the whole engine sub-frame has to be dropped to get the front sway bar in. Then a wheel alignment was done as the ALK changes the geometry of the front end.
Now since this time I've been working with the guys at Whiteline and the local Pedders who are the Whiteline dealer (wish I'd found this out earlier as I would have got them to fit the bar) to sort out the fitment issues.
Since the first post, I've had the washers taken out from under the mounts for the front sway bars and links put in to move the sway bar away from the lower suspension arms. This has meant the tailshaft no longer makes contact with the sway bar (makes an awful racket when it happens).
I've also had the anti-lift kit removed and stock unit re-installed as the housing for the Whiteline ALK did not fit properly. When bolted to the chassis rail there was about 5mm space between the mount and the subfame which had to be spaced out with washers.
The car has now had another wheel alignment done to correct for putting the old lower control arm bushes back on.
So two steps forwards one step back at the moment...
Steering is noticeably lighter now, but doesn't turn in anywhere near as well as before with the ALK on.
