If you're just doing the rear I would consider the 22. If you were doing both I'd go the 24 front and back.
That's just my gut feel and based on having the 24 on the back of mine with the stock sway bar on the front. I think in this configuration the back is stiffer than the front.
You probably want to have it the other way around with front stiffer or at least balanced. That's my thoughts.
Also I wouldn't bother changing the front sway bar unless you were running it on the track.
