Yes, that combined with **** roads that flog the guts out of the poor little beast
Sent from my PadFone 2 using Tapatalk 2
Good to hear!
I had the exact same problem when I had the Mk5 GTI!
But unfortunately wasn't so lucky getting it replaced under warranty, as I also changed the shocks to Koni FSD.
They definitely said that it was my problem!
So had to bloody fork out money for the front strut mounts and install elsewhere.
Sounds like a routine part that needs replacing whenever you're thinking of doing a front suspension mod.
I'm sure others have changed the springs in their Tigs and have had no knocking sound from the strut mounts.
But the fact that you've also had this problem and in a Tig suggests that it's not a random issue.
It's either the Eibach springs or the strut mounts that is allergic to the other.
MY11 Tiguan 147TSI (SOLD)
2011 147TSi 7spd DSG Reflex Silver, 18" New York Alloys, Leather with MDI, ECB Nudge Bar, Viezu Tune (Work in Progress), Eibach ProKit Springs, SuperPro Poly ALK & Rear Trailing Arm Bushes, H&R 26mm Rear ASB and Whiteline HD Adjustable End-Links, VAR Design 3" Downpipe, Sprint Booster, Auto-Polar FIS+ Advanced Module, GTI Sports Pedals, Flappy Paddle Strg Wheel, LED fogs as DRL, chrome blingy bits
Hmm, I have the same symptoms (and have also replaced the springs)
Try for warranty - worked for me (I think it's a reasonably common problem, springs or not)
P.S: got any pics of the beast - I reckon the Octy Wagon is a real sleeper (like the Tig)![]()
Weird. Wouldn't be due to lower ambient temp when raining/wet? Maybe oil in shocks not viscous enough when hot (what it sounds like)?! I avoided FSB shocks because there seemed to be quite a few failures with them.
Sent from my ZTE T28 using Tapatalk 2
Hi Tigger,
Your post was the first reference I found on the "squeaky bed springs" noise from the front suspension - that is just what I get over the shopping centre "speed bumps" and gutters at slow speed. The first dealer I took the car to gave the usual "they all do it" and "wind the windows up" and "don't worry, it will be OK" !
I would appreciate the part numbers that you used - that will be a start. Many thanks for the forum and help.
