I got mine done at volksworks but that was part of a brake upgrade
Any good aftermarket brake shop should be able to help you so shop around
The ceramic brake pads are more expensive than stock but last much longer so cost works out even over the long run
As for rotors you can go stock again or aftermarket up to you and what you want to pay just remember that the crossdrilled/vented rotors like the db2 /db3/db4 wont do anything for the braking experience they are just there to look good
so if your not showing them off just go for plain blank ones
2017 Golf Alltrack 135tdi All options
19 inch Brescia Wheels Golf R brakes front and rear
Calipers painted Candy apple gold
New rear sway bar and linkages
