Results 1 to 10 of 17
Thread: Fog Light
    Fog Light
    Hi everyone,
    I am new here. Just order my new Tiguan on Tuesday and I stupidly did not order it with fog light. So I have rang my dealer today and wanted to add it, they told me the car is already scheduled for production and I cannot change my order.
    So I am wondering if anyone in this forum have fitted the after market fog light on to the Tiguan ?
    Thanks in advance
    a fat boy......
    Customer Contract Date
    Order Entry Dealer System
    16/02/09
    Order Entry NADIN
    16/02/09
    Order Registration IFA
    16/02/09
    Buildability Check
    16/02/09
    SGW Rebooking
    16/02/09
    Current SGW Determination
    16/02/09
    Allocation of product plant
    18/02/09
    Handover to production
    18/02/09
    Start Body Shell Shop
    20/03/09
    End Body Shell Shop
    Start Paint Shop
    21/03/09
    End Paint Shop
    Start Final Assembly
    23/03/09
    Checkpoint 8 Handover to Sales
    24/03/09
    Start Service Shop
    End Service Shop
    Exit Production Plant
    27/03/09
    Arrival Port of Shipment
    31/03/09
    Departure Port of Shipment
    7/04/09
    Departure last Port of Transit
    Arrival at Port of Destination
    18/05/09
    Departure from Port of Destination
    18/05/09
    Arrival at final Destination
    19/05/09
    Jul 2005
    You should be able to buy them from spare parts & fit/have them fitted.
    May cost a little more but you'll have the proper factory units.
    I had factory foglights fitted to my T4 Transporter by Trakka in Sydney, they didn't cost that much more.
    Maris
    VW sales said there are nothing they can do. Now I just have to purchase one and ask a garage to fit it. Will try to find out something about Trakka and see.
    Jul 2005
    Quote Originally Posted by afatboy View Post
    TRAKKA won't do it ask they only deal with campervans.
    Your Dealer will be able to, so why not ask the salesperson who sold you the Tiguan to do you a deal on retro fitting? Nothing to loose. If they won't come to the party, ring around other Dealers.
    Maris
    Jan 2009
    Quilpie, Qld
    Fogs
    See thread below on driving lights.
    Jun 2008
    South Coast N.S.W.
    I wouldn't consider it would be too late to add these to your order, I would try again and insist that you want them. IMO the dealer is being a bit lazy because I very much doubt that it couldn't be done if they press the right buttons. Then again after recent dealings myself with VW (Australia) there's always the possibility that making any changes now could end up seeing the wrong model VW turn up as your order so it might be safer to have them fitted once you get it.
    Russ
    Russ
    2005 Subaru Outback 3.0 R Premium
    Dec 2008
    Alexandra, New Zealand
    I fitted them to mine see
    http://www.mytiguan.com/viewtopic.ph...5357&hilit=fog
    or http://www.vwwatercooled.org.au/newf...ad.php?t=23945
    No big deal, just a hassle getting them from GB etc but perfectly doable.
    Derek
    Alexandra
    2022 R-Line Golf Mk8 in Kings Red Metallic
    Previously 3 Tiguans 2008, 2013, 2017
    Quote Originally Posted by Russ59 View Post
    Russ
    I try and they insist they cannot do anything....
    Dec 2008
    Quote Originally Posted by WEDEL.1 View Post
    Maris
    The only problem with dealers is that they'll ONLY do it "to the book", that is with all the factory wiring, switches, etc etc. I got an "estimate" from the dealer to fit front fogs to mine and they wanted at least $1600 !! I did it myself for under $500 wired and working. IN NZ it's a $600 option on new so I'm pretty darn happy. The only issue you have fitting them yourself is where you wire them to switch wise. In NZ we have a rear fog as standard so we just put in a relay off that switch and wired the front through that relay but powered direct from the battery. That way ALL my fogs turn on together and I didn't have any problems with the computer "finding" too high a loading on that circuit. Works like a charm for me BUT if you don't have a rear fog already fitted you'd either have to get the correct replacement light switch and have it all coded etc OR wire a separate switch somewhere.
    Guess the other option, if you don't really NEED fogs but just want "the look", would be to get some standard fogs that would look OK and just do a "No8 fencing wire" job to make it "appear" as if you have fogs when it's just the reflector, bulb and glass "stuck" in the hole.
    Other thing to remember is that the Tig is a relatively NEW model and a lot of this gear will become more available over time.
    Derek
    Alexandra
    Aug 2006
    Far North Qld
    Quote Originally Posted by NZTiguan View Post
    In Oz we have the fog as standard as well...
    thanks, Derek for your always very informative posts!
