Page 16 of 23 FirstFirst ... 61415161718 ... LastLast
Results 151 to 160 of 224
Thread: Flappy paddles steering wheel in Tiguan.
  1. #151
    Aug 2009
    Just done the swap, now my car is paddles equipped!
    There's slight delay in shifting as pressing the button and waiting the gearbox to shift. DSG is quite instant, slight delay in tiptronic gearbox, it's understandable I guess.
    I found in manual mode, the gearbox still downshift by it self. Ah well, at least I have more control of the gearbox.
  2. #152
    Oct 2010
    Great to hear! Which steering wheel did you end up getting?
  3. #153
    Aug 2009
    I have the normal flappy one from an EOS or jetta i think.
    I didn't go for the GTi steering wheel as I want to keep the factory look. I may regret later lol, but for the time being I'm happy.
  4. #154
    Oct 2010
    Yes you my regret it. There's always time for change.
  5. #155
    Feb 2013
    Perth, WA
    I'm looking at doing the swap.
    Is this the right wheel for the Tig without having to change the airbag as well?
    VW DSG + Multifunction Steering Wheel - 3C8419091AP E74 - EOS Golf Passat
    Cheers.
  6. #156
    Quote Originally Posted by Wynnston View Post
    Cheers.
    It looks like the right shape - it's the round wheel instead of flat bottom one (I have flat bottom "R" wheel and that needed a new airbag). Though best to ask the guys on the website to confirm the part # for the airbag and then check this against what you have if you want to be certain.
    The safest way to do this is with VCDS - here's the scan of the hardware bits in my car:
    Address 15: Airbags Labels: 5N0-959-655.lbl
    Part No SW: 5N0 959 655 R HW: 5N0 959 655 R
    Component: J234__202 VW10 HI 1918
    Revision: 22014000 Serial number: 003K0P4KFLN2
    Coding: 0012338
    Shop #: WSC 01324 020 00200
    VCID: 4C9D1A552FDD2C788DD
    No fault code found.
    Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
    Part No SW: 5K0 953 521 AT HW: 5K0 953 569 B
    Component: LENKS.MODUL 014 0140
    Revision: FF010040 Serial number: 20110309100699
    Coding: 1892140000
    ASAM Dataset: EV_SMLSNGVOLWSXS A01004
    ROD: EV_SMLSNGVOLWSXS_VW36.rod
    VCID: 7EF9809DE1E14EE8539
    Multifunction steering wheel control module:
    Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
    Component: E221__MFL-TAS H08 0010
    Coding: 830000
    Though as I said I have the flat bottom sports wheel which has a different shaped airbag than the "stock" Tig wheel.
  7. #157
    Jul 2010
    If it looks like the one you have now Wynnston, then it should be fine and save yourself the cost of an airbag!
    But what tigger73 said for safe measure!
    Although I think he meant Part No and not serial no.
    MY11 Tiguan 147TSI (SOLD)
  8. #158
    Corrected. Other thing you need to keep in mind is that there are a couple of different methods for the airbag to fasten to the wheel. So you need to get the airbag that has the same clip method as the wheel.
    As far as I can tell these are the 2 key things is correct shape and matching mounting clippy things (that's the technical term). There's only 2 wires to the airbag and I'm pretty sure this is just the trigger.
  9. #159
    Feb 2013
    Perth, WA
    Ok thanks.
    I'm a little confused, I can't seem to see a part where it says "disconnect battery" whilst doing the install. Do you all leave it plugged in while changing out the airbag....?
  10. #160
    Ok thanks.
    Seriously if you don't know what you're doing don't touch it as people have been killed by airbags accidentally deploying.
    If you're going to swap it yourself make sure you fully discharge the electrical system and yourself (i.e. static) first.
