Great to hear! Which steering wheel did you end up getting?
Just done the swap, now my car is paddles equipped!
There's slight delay in shifting as pressing the button and waiting the gearbox to shift. DSG is quite instant, slight delay in tiptronic gearbox, it's understandable I guess.
I found in manual mode, the gearbox still downshift by it self. Ah well, at least I have more control of the gearbox.
I have the normal flappy one from an EOS or jetta i think.
I didn't go for the GTi steering wheel as I want to keep the factory look. I may regret later lol, but for the time being I'm happy.
Yes you my regret it. There's always time for change.
I'm looking at doing the swap.
Is this the right wheel for the Tig without having to change the airbag as well?
VW DSG + Multifunction Steering Wheel - 3C8419091AP E74 - EOS Golf Passat
Cheers.
It looks like the right shape - it's the round wheel instead of flat bottom one (I have flat bottom "R" wheel and that needed a new airbag). Though best to ask the guys on the website to confirm the part # for the airbag and then check this against what you have if you want to be certain.
The safest way to do this is with VCDS - here's the scan of the hardware bits in my car:
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 R HW: 5N0 959 655 R
Component: J234__202 VW10 HI 1918
Revision: 22014000 Serial number: 003K0P4KFLN2
Coding: 0012338
Shop #: WSC 01324 020 00200
VCID: 4C9D1A552FDD2C788DD
No fault code found.
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 521 AT HW: 5K0 953 569 B
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20110309100699
Coding: 1892140000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWSXS_VW36.rod
VCID: 7EF9809DE1E14EE8539
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H08 0010
Coding: 830000
Though as I said I have the flat bottom sports wheel which has a different shaped airbag than the "stock" Tig wheel.
If it looks like the one you have now Wynnston, then it should be fine and save yourself the cost of an airbag!
But what tigger73 said for safe measure!
Although I think he meant Part No and not serial no.
MY11 Tiguan 147TSI (SOLD)
Corrected. Other thing you need to keep in mind is that there are a couple of different methods for the airbag to fasten to the wheel. So you need to get the airbag that has the same clip method as the wheel.
As far as I can tell these are the 2 key things is correct shape and matching mounting clippy things (that's the technical term). There's only 2 wires to the airbag and I'm pretty sure this is just the trigger.
Ok thanks.
I'm a little confused, I can't seem to see a part where it says "disconnect battery" whilst doing the install. Do you all leave it plugged in while changing out the airbag....?
