Page 15 of 23 FirstFirst ... 51314151617 ... LastLast
Results 141 to 150 of 224
Thread: Flappy paddles steering wheel in Tiguan.
  1. #141
    Oct 2010
    coding
    Go to long coding and enable the option. Just need to tick the option
    Hi Tigger73, when I press coding it comes up with screen i took a picture of, cannot go into long coding or any other options.
    I think I have to do it manually?
    MY10 Tiguan 125TSI /APR Stage 2
  2. #142
    Oct 2010
    Maybe I have to change the coding? Originally the coding was 0001132. Do I change it to 0001232 because now I have triptronic? Or which one do I change to enable paddles?
    Regards
  3. #143
    Apr 2010
    Quote Originally Posted by Suffolk View Post
    Finally decided to install my paddle shift steering wheel, very easy!
    Luckily i didn't have to change my airbag as i had the same steering wheel but without paddles and different shape.
    http://imageshack.us/a/img831/1956/dsc01808aw.jpg
    Only problem i'm having is getting paddles to work.
    Got the pop up menu below and not sure what to do.
    Original coding below
    Anyone can help??
    Hi there
    Note how it says 0xxx?xx just above the section regarding tiptronic (paddles)
    So the ? is the digit to change (3rd from right)
    Yours currently is 1 (00011132)
    "1 OR 5" = No Tiptronic and no PTT
    You want to change it so that you do have Tiptronic and no PTT
    So change it to 2
    New coding is 00011232
    Job done
  4. #144
    Oct 2010
    Coding is 0001232. No long coding for this one. Ryan_R is correct! Thankyou
    Job Done
  5. #145
    Job Done
    Good to hear you got it going. With mine it gave the option for long coding (same as AussieTig in post #2). Good to see that you got it sorted. Enjoy your flappy paddles!!!
    Oct 2010
    Just did. Over it, next mod!
  7. #147
    Aug 2009
    Suffolk,
    does the flappy paddles work when you just leave in D? or do you have to shift to Tiptronic mode before you can use the paddles
  8. #148
    Oct 2010
    Baboo,
    Good thing about paddles is that they also work in D. Press + on paddles and it's activated. Press OFF, and you will go back
    to Auto.
    Had to explain it to the wife just in case she pressed one of the paddles and didn't know what to do. Great upgrade, especially if you don't
    Need to buy another airbag.
  9. #149
    Aug 2009
    Thanks for that! so it works the same as DSG one in my golf so it's good to know.
    I already ordered the steering wheel, so it's good to know you got it working. Thanks!
  10. #150
    Quote Originally Posted by baboo View Post
    Suffolk,
    Actually it will revert to D after about 20-30 seconds. Same if you're driving in S and hit the paddles to upshift it will revert in 20s and downshift back...
    I use my paddles 90% of the time.
