VW GOLF VI MK6 EOS CADDY PASSAT SCIROCCO DRIVER AIRBAG | eBay
Try that guy.
I just purchased a passat premium cluster from him. I purchased a wheel intact with air bag for about $800 shipped, figured it was just easier to get the entire unit. Probably a little expensive but easy and shipped in 4 days from europe
Success!!!!!
12mm triple square bit arrived yesterday and the airbag came this morning (yes Saturday delivery). After a bit of mucking around with a screw driver and the clips on the back of the airbag it came out pretty easily in the end.
Needed a converter for the triple square bit to take from 1/2" drive to 3/8" for the ratchet but other than that it went pretty smoothly.
Threw a steering wheel fault when I turned it back on but drove down the road and the fault cleared.
Just waiting now to get it hooked up onto Vagcom and enable my flappy paddles...
That's exciting news. Well done! I still havent got my airbag yet. Still scouting ard. I will have to get the 12mm bit too. Any photos mate?
Here's the end result. Type R flat bottom wheel, red stitching and DSG paddles!!!!
That's a beauty mate. Hope mine turns out that way too!
Doesn't the R wheel normally come with blue stitching?
I think you'll find all the local delivered Type R's have black stitching on the steering wheels. Red is probably a spec from another country.
On a separate note I just noticed there's a GTI wheel with DSG paddles on ebay Australia:
VW GOLF 6 GTI STEERING WHEEL DSG | eBay
However if you get it you'll still need to get the airbag.
A quick trip to my favourite mobile mechanic (Transporter) and 30 seconds later the paddles are switched on.
So now gear changing is a breeze. Downshifting when going down hills and you want some engine braking or upshifting when driving in "S" and the DSG transmission stays in gear too long. Plus you can shift it back into 1st when you need to get going at low speed.
Yes it's a relatively expensive upgrade given the functionality increase is relatively minor (and would have been way cheaper to include paddle shifters with the vehicle as an option from new) but for me it makes the car a lot more driveable. It allows you to get around some of the annoying DSG transmission issues.
So for the record I was able to use my existing SWCM and airbag cable from my 2011 Tiguan and just purchase the wheel and matching airbag. The only thing that I regret is that I didn't do it sooner!![]()
