Originally Posted by
WEDEL.1
Your Dealer will be able to, so why not ask the salesperson who sold you the Tiguan to do you a deal on retro fitting? Nothing to loose. If they won't come to the party, ring around other Dealers.
Maris
The only problem with dealers is that they'll ONLY do it "to the book", that is with all the factory wiring, switches, etc etc. I got an "estimate" from the dealer to fit front fogs to mine and they wanted at least $1600 !! I did it myself for under $500 wired and working. IN NZ it's a $600 option on new so I'm pretty darn happy. The only issue you have fitting them yourself is where you wire them to switch wise. In NZ we have a rear fog as standard so we just put in a relay off that switch and wired the front through that relay but powered direct from the battery. That way ALL my fogs turn on together and I didn't have any problems with the computer "finding" too high a loading on that circuit. Works like a charm for me BUT if you don't have a rear fog already fitted you'd either have to get the correct replacement light switch and have it all coded etc OR wire a separate switch somewhere.
Guess the other option, if you don't really NEED fogs but just want "the look", would be to get some standard fogs that would look OK and just do a "No8 fencing wire" job to make it "appear" as if you have fogs when it's just the reflector, bulb and glass "stuck" in the hole.
Other thing to remember is that the Tig is a relatively NEW model and a lot of this gear will become more available over time.
Derek
Alexandra
2022 R-Line Golf Mk8 in Kings Red Metallic
Previously 3 Tiguans 2008, 2013, 2017
